Charger door panels seem loose, any body else have a problem like that?
Discussion in 'Dodge Charger SRT Hellcat' started by CanuckH3llKat, Apr 10, 2015.
  1. CanuckH3llKat
    CanuckH3llKat Silver Member
    Feb 18, 2015
    258
    57
    Calgary
    Does anybody else have an issue with the front inside door panels feeling a bit loose? What I mean is, that when I pull on the handle to close the door and I don't pull hard enough the doors don't close because the handles have some give on them. You can actually push and pull them and they will move about a 1/4 of an inch and kind of click. Is this normal or should I take it in to have a tech look at it?
  2. Colorado Hellcat
    Colorado Hellcat Silver Member
    Nov 13, 2014
    549
    125
    It sounds like the door panel was removed for some reason & now the Door Panel retainers are bad & not holding.
    I'd take it to the dealer & have new ones put in unless your comfortable doing it yourself.
  3. CanuckH3llKat
    Feb 18, 2015
    258
    57
    Calgary
    But both front doors are the same. Its a small fix though and won't make things worse if they pull the panels off?
  4. Cruisin1966
    Cruisin1966 Silver Member
    Nov 8, 2014
    1,106
    235
    198
    Calgary
    Apparently your Hellcat is rejecting you. Drive downtown Calgary and drop it off with me. I believe that is your only hope for happiness. ;)
    • Funny Funny x 1
  5. CanuckH3llKat
    Feb 18, 2015
    258
    57
    Calgary
    hahaha, ya, sure when you get your sublime in we can trade!!! lol I'll just mention to the dealer when I take it in tomorrow, they are replacing a scratched console. I didn't even know it was scratched and didn't even notice until the called me that my part was in..
  6. Mike Canadian
    Mike Canadian Silver Member
    Jan 21, 2015
    278
    66
    In Canada we have the "Lemon Law" and it sounds to me that you need to paint the car yellow...just kidding.
    Have it checked out by the dealer. Sounds like you have a good one!;)
  7. Colorado Hellcat
    Nov 13, 2014
    549
    125
    Hummm? If both are the same I'm not sure what's up. Just sounds like the center retainers are gone or bad. Have you tried pushing firmly in the center of the panel? If it locks or pops in for a bit until you pull it hard. You said it is clicks. That tells me the ribs on the retainer is not holding.
  8. Colorado Hellcat
    Nov 13, 2014
    549
    125
    What's the word?
  9. Brampton Builder
    Brampton Builder Gold Member
    Dec 13, 2014
    434
    310
    513
    They are all like that , the screw in the door pull cup feels loose when you pull the door closed. You don't need to remove the panels just pop the screw cover off and tighten the Phillips screw a little more. There are only 3 screws holding front door panel on . One under the handle to open the door , one at the door pull handle and one that holds that little rubber donut. The rest of the panel is held in with plastic pins
    • Useful Useful x 4
2010 charger door handle came loose
2014 dodge charger door panel repair
2015 dodge charger door panel coming off
2015 nissan rogue loose door panel
door panel loose after removal
inside rode for dodge charger came loose how to fix
my door handle broke on my 2014 dodge charger
plastic panel loose on charger
