Charger Hellcat rear view mirror
Discussion in 'Dodge Charger SRT Hellcat' started by ChargeCat, May 9, 2015.
  1. ChargeCat
    ChargeCat Senior Hellcat Member
    Feb 2, 2015
    125
    41
    Brampton Builder
    Any information available on how to disassemble the rear view mirror on the Charger Hellcat? I am trying to access power from the mirror for a radar detector. I wiggled and pulled on it to no avail! Please help!!
  2. B5 Blue
    1,745
    Someone did the Challenger and didn't find a good source there
  3. ChargeCat
    Feb 2, 2015
    125
    41
  4. B5 Blue
    1,745
    I stand corrected
  5. ChargeCat
    Feb 2, 2015
    125
    41
    fnkychkn
    Do you have access to any info/diagrams? I'm stumped!
  6. ChallCat
    ChallCat Gold Member
    Nov 15, 2014
    423
    250
    Kansas City
    You have to rotate the whole assembly counter clock-wise about 1/4 turn to get it off. And it's a mofo to get back on.... be firm, but don't press forward too hard or you can crack your windshield. Took me friggin 2 hours to put it back on....
  7. BlackCat15
    BlackCat15 Silver Member
    Dec 9, 2014
    161
    28
    Ontario Canada
    The mirror itself is held together with clips and takes some serious prying to get the first clip then they come pretty easy.
    I have disassembled pics if that's any help.
  8. ChargeCat
    Feb 2, 2015
    125
    41
    Pics would be a HUGE help & very appreciated! I am scared too death of breaking it.
  9. BlackCat15
    Dec 9, 2014
    161
    28
    Ontario Canada
    I don't have as many as I thought, here's one showing where it "clips" on. This gives an idea of how far "under" the housing you have to go in order to pry it off.
    I would recommend prying on the top passenger side since you will likely leave some tiny marks and they won't be visible if you start in that corner. Once you get the first clip the rest are really easy. I had to put enough pressure with a small flat screwdriver that I thought breaking it was a strong possibility.
    Installing a display behind the mirror?
  10. ChargeCat
    Feb 2, 2015
    125
    41
    I am actually only trying to disassemble the trim around the mirror attachment to the window (not the mirror itself) so that I can access the power and ground that feed into the back of the actual mirror in order to power a radar detector.
  11. BlackCat15
    Dec 9, 2014
    161
    28
    Ontario Canada
    Ahh, thought you might be putting radar display inside the mirror.
    Removing mirror shroud is easier, just apply pressure and pull. You can remove the mirror itself by twisting the base.
    Power can also be had by pulling down the overhead light unit which is held by four clips - carefully - mine had sharp edges.
    I personally would run a cable from the fuse box and up the pillar with a fuse tap from the switched accessory power. I'd suggest a kill switch too so you don't have to reach for detector to turn it off.
  12. fnkychkn
    Jan 24, 2015
    1,489
    603
    greasy cardboard box
    TELEMATICS MIRROR
    [​IMG]
    1. Disconnect and isolate the negative battery cable.
    2. Using a small flat bladed tool, release the clips (2) on each side of the upper mirror trim (1) and rotate the upper mirror trim downward to remove.
      [​IMG]
    3. Using a small flat bladed tool, release the tabs (2) and lower the lower mirror trim and remove.
      [​IMG]
    4. The lower mirror trim (2) is shown removed, pry both tabs (1) outward to release.
      [​IMG]
    5. Disconnect the wire harness connector (2) from the mirror.
    6. Grasp the mirror (1) by the base and rotate it clockwise approximately 90 degrees and remove.
    at mirror 10 way connector, you should find switched 12V at cavity 5 (F924 circuit, pink/yellow 20 guage wire) and ground at cavity 4 (Z910 circuit, black 20 guage wire).
    • Useful Useful x 3
  13. ChargeCat
    Feb 2, 2015
    125
    41
    fnkychkn
    The trim behind the mirror/around the mirror stalk on the Charger is different from the pictures above. I can't get this thing off for the life of me!
    BlackCat15
    Where do I need to aplly pressure and which direction do I pull? It seems to be 2 pieces of trim but I can't get them apart or either off.
    NX91Notch
  14. fnkychkn
    Jan 24, 2015
    1,489
    603
    The pics I posted are from charger service manual.
  15. ChargeCat
    Feb 2, 2015
    125
    41
2016 challenger mirror
2016 challenger rear view mirror
challenger rear view mirror shroud removal
challenger silver with black mirrors
dodge charger 2014 rearview mirror installation
dodge charger rear view mirror wont go on base on windshield
how to install dodge charger back mirror
how to replace rear interior mirror 2015 dodge charger
