Check Engine Light
Discussion in 'SRT Hellcat Maintenance' started by Daniel Carter, Feb 15, 2015.
  1. Daniel Carter
    Daniel Carter Gold Member
    Oct 30, 2014
    281
    155
    Ewa Beach, Hawaii
    Check engine light popped on today at 2153 miles! P1524 code, any ideas?
  2. fnkychkn
    Jan 24, 2015
    1,503
    612
    greasy cardboard box
    P1524-OIL PRESSURE OUT OF RANGE - CAMSHAFT ADVANCE/RETARD DISABLED
    When Monitored: This diagnostic runs continuously when the following conditions are met:
      • With the engine running.
      • Battery voltage above 11.49 volts.
      • Engine speed above 1100 rpm.
      • Oil temperature between 7.0°C (44.6°F) and 188.0°C (370.4°F).
      • No active Engine Oil Temperature Sensor or Engine Oil Pressure Sensor circuit faults.
      • No active Cam/Crank Misalignment or VVT Solenoid performance faults.
    Set Conditions:
    • The engine oil pressure never reaches the calibrated specification to allow the VCT activation.
    Default Actions:
    • The MIL light will illuminate.
    Possible Causes
    ENGINE OIL/ENGINE MECHANICAL
    ENGINE OIL PRESSURE SENSOR
    POWERTRAIN CONTROL MODULE (PCM)
    not sure i'd want to drive it like that. best get it towed to your dealer just to be safe.
    good luck, hope it's not too serious.
  3. Daniel Carter
    Oct 30, 2014
    281
    155
    Ewa Beach, Hawaii
    I took the car in today and apparently that means the oil level is low. So it is topped off now. I will check it again in two weeks to get a baseline on how quickly it is burning through the oil. I am wondering if maybe it wasn't properly filled when I picked it up. Hmm..
  4. fnkychkn
    Jan 24, 2015
    1,503
    612
    how low was it? it would need to be extremely low to affect oil pressure.
  5. Next Phase
    Next Phase Silver Member
    Oct 22, 2014
    908
    301
    173
    Gen 5 Vipers have reported to go through some oil during break in...
    I'd check the oil every fill up for the first 2k miles. How many quarts low were you?
  6. Sublime 70
    Sublime 70 Gold Member
    Oct 21, 2014
    260
    116
    I check my oil everytime i drive my cat!!
  7. Daniel Carter
    Oct 30, 2014
    281
    155
    Ewa Beach, Hawaii
    I fill up twice a week and don't check very often. Clearly I need to check more often, never used to having to check that often.
  8. Daniel Carter
    Oct 30, 2014
    281
    155
    Ewa Beach, Hawaii
    Some Chrysler staff and maintenance staff came to Hawaii this week and what was passed to the service dept in regards to oil was for the first 5k miles the rate of oil consumption is about a quart every 1k miles. FYI.
    Mine went through 2 quarts in 4 days, getting looked at now.
    • Useful Useful x 4
  9. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    That's not normal,, that's a lot of oil,,I don't think I would be driving that until they fix it.. please keep us updated,
  10. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Keep us posted, that sounds very abnormal
    • Agree Agree x 3
  11. Daniel Carter
    Oct 30, 2014
    281
    155
    Ewa Beach, Hawaii
    It is still in the shop. I'll keep you updated.
  12. TallCool1
    2,433
    818
    Pacific NW
    Re the staff comments, if they shared factual info, to me following oe break in guidelines makes sense. And warming up the engine before you get on it.
  13. HellcatKid
    HellcatKid Silver Member
    Dec 21, 2014
    465
    116
    CANADA
    1 Quart of oil being consumed every 1000 miles is by no means normal imho ! that's just the b.s. guidelines every mfg goes by for warranty purposes. 2 quarts in 4 days :eek: Houston we have a problem!........ very interested to see what they find for you man and hope its nothing too serious! :(
  14. solo7777
    Nov 25, 2014
    3,105
    1,401
    768
    City Of The Angels
    I've only had to put in 1/2 quart. At 4500 miles.
  15. Daniel Carter
    Oct 30, 2014
    281
    155
    Ewa Beach, Hawaii
    Hopefully they have an answer and a fix to the issue tomorrow, so I can have her back. I will post what they say.
    Build #21 Nice!! Mine is 171.
2016 dodge challenger 392 check engine light problems 008 code
can you still drive car with code p1524
check engine light 2015 challenger
check engine light reset on dodge challenger hellcat
diagnostic code p1524
diagnostic code p1524 on 2016 dodge challenger hellcat
engine light on hellcat from low battery
p1524 dodge ram
