Check Engine Light
Discussion in 'SRT Hellcat General Discussions' started by Beelzebub, Mar 10, 2015.
  1. Beelzebub
    Beelzebub Gold Member
    Oct 13, 2014
    198
    109
    So my Cat threw a code P018D so I took it in and was told it's a stored code and they cleared it, 1 week later it's back so now I have a appointment to take it back. Anyone else throw this code? It's fuel injector sensor I think
  2. tsc
    tsc SRT Hellcat Enthusiast
    Oct 27, 2014
    1,520
    696
    563
    Cincinnati, OH
    Only codes I've thrown is when I pulled the active exhaust fuse. P018D is 'Fuel Pressure Sensor Circuit High Voltage'. Wish I had more info.. I can't remember if the Diagnostics page in the DID only displays active codes, or if it displays stored/historical codes too. Try disconnecting your battery and see if the code is still there. If it isn't it was stored..
    Probably still worth a trip to the dealer regardless.
  3. WhoFlungPoo
    WhoFlungPoo Silver Member
    Nov 17, 2014
    284
    128
    Mine had same exact problem at delivery. The car will only run moderate while sensor is bad but drivable. Once they replaced it it was like the hounds of hell were let loose and hold on for dear life. Big difference once replaced. My tech only took him 45 minutes to replace and did not have to remove anything to get to it.
  4. Beelzebub
    Oct 13, 2014
    198
    109
    Thanks WhoFlungPoo I needed to hear that
  5. fnkychkn
    Jan 24, 2015
    1,450
    558
    423
    plastic take-out container
    P018D-FUEL PRESSURE SENSOR CIRCUIT HIGH
    Theory of Operation
    The Powertrain Control Module (PCM) provides a 5-Volt supply to the Fuel Rail Pressure Sensor (FRPS). The PCM also provides a ground on the sensor return circuit. The Fuel Rail Pressure Sensor provides a signal to the PCM on the Fuel Rail Pressure Sensor Signal circuit. This sensor signal voltage changes based on the pressure in the fuel rail. The PCM will detect a low signal voltage at low rail pressures. The PCM will detect a high signal voltage during high rail pressure conditions.
    When Monitored: This diagnostic runs continuously when the following conditions are met:
    • With the ignition on.
    • Battery voltage greater than 10.4 volts.
    Set Conditions:
    • The Fuel Rail Pressure Sensor (FRPS) signal circuit voltage is above a calibrated threshold for a certain period of time.
    Default Actions:
    • The MIL light will illuminate.
    Possible Causes
    FRPS SIGNAL CIRCUIT SHORTED TO VOLTAGE
    FRPS SIGNAL CIRCUIT OPEN/HIGH RESISTANCE
    FRPS SIGNAL CIRCUIT SHORTED TO THE 5-VOLT SUPPLY CIRCUIT
    SENSOR GROUND OPEN/HIGH RESISTANCE
    FUEL RAIL PRESSURE SENSOR <<< most likely cause
    POWERTRAIN CONTROL MODULE (PCM)
  6. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    671
    224
    Mine has been on the battery tender since Dec. Started it up yesterday to lube things up and I have a check engine light now? I did have the fuel pump fuse out so I could spin the motor once and a while. (was later told to just floor the gas and it wouldn't start) You guys have scanners to check codes or is there a function on the car?
  7. Beelzebub
    Oct 13, 2014
    198
    109
    scroll thru to diagnostic then hit ok and it will search for code and display if found
  8. MVT
    MVT Silver Member
    Jan 11, 2015
    1,079
    307
    Thanks WhoFlungPoo I need to say that!:)
  9. paul suloff
    Aug 25, 2014
    671
    224
    Thanks found it U0109 Lost communication to fuel pump. Logical since I pulled fuse over winter. Assume I just disconnect battery to reset?
  10. Beelzebub
    Oct 13, 2014
    198
    109
    Yep that should do it
  11. Yearight1999
    Yearight1999 Silver Member
    Feb 2, 2015
    167
    29
    Alvin, TX
    This threat was difficult to read. I mean really, a conversation between Beelzebub and WhoFlungPoo, then throw in fnkychkn.
    • Funny Funny x 1
  12. Yearight1999
    Feb 2, 2015
    167
    29
    Alvin, TX
    Great information though
2013 dodge ram 1500 p018d
2013 dodge ram 1500 p018d location
2013 ram p018d
check engine light on hellcat
dodge ram p018d
p018d code dodge ram
p018d ram
