check engine light?
Discussion in 'Dodge Challenger SRT Hellcat' started by CO Springs Sublime Kitty, Apr 5, 2015.
  1. CO Springs Sublime Kitty
    CO Springs Sublime Kitty Gold Member
    Apr 2, 2015
    203
    125
    I have 200 miles on my HC and got a check engine light on today after a little bit of spirited driving but nothing too crazy. No high RPM shifting or launching the car. All gages read perfect, thoughts?
  2. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    RUH roh did you punch it too hard before 500 miles? :eek: Check to see if there's some error code in the log event
  3. CO Springs Sublime Kitty
    Apr 2, 2015
    203
    125
    I have a P0069 code. How do I check what that means?
  4. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    Well since its a new hellcat then it can't be a dirty filter UNLESS it came dirty since it was sitting at the yard for too long before it got delivered to your dealership. If that is the case then replace the air filter and reset the code and see if it happens again. If it does happen again after that then It could also be the intake air temperature sensor.
  5. CO Springs Sublime Kitty
    Apr 2, 2015
    203
    125
    Ok thank you so much! I will have the dealer replace it since it's brand new!! Plus then they can reset the code, right?
  6. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    Yeah they should be able to easily. Have them replace the air filter first and make sure there are no air flow problems. It may be other causes of the code hope someone else chimes in.
  7. CO Springs Sublime Kitty
    Apr 2, 2015
    203
    125
    Ok will do. How is is that you can tell what the code means? Do you have a master list or something?
  8. Thebossaudio
    Thebossaudio Silver Member
    Mar 4, 2015
    198
    32
    Google
  9. B5 Blue
    1,745
    69= you're F****d
    • Funny Funny x 2
  10. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    Well i have some codes in my book and I researched some from the net over time.
  11. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,383
    768
    Slinger Wisconsin
    Theory of Operation
    [​IMG]
    The 6.2L engine uses several sensors to monitor the air pressure and temperature throughout the intake air system. The PCM uses this information to help calculate fuel delivery, ignition timing and Supercharger control. The PCM runs diagnostics to check the rationality of the sensors. The Supercharger Inlet Pressure Sensor is the centralized sensor in the system and is the main sensor used for the rationality diagnostics of the airflow before and after the Throttle Body.
    Individual MAP/Pressure Sensor rationality diagnostic checks:
      • At ignition on, engine not running, the BARO Sensor and four MAP/Pressure Sensor input signals are compared. If one of the MAP/Pressure Sensor input signals has a difference of more than a calibrated threshold from the others, a performance fault is set against that sensor.
      • With the engine running, the input signals of the three MAP/Pressure Sensors that are downstream of the Supercharger Inlet Pressure Sensor (Supercharger Outlet Pressure Sensor, Bank 1 MAP, Bank 2 MAP) are compared. If one of the sensor input signals has more than a 10.0 kPa (1.5 psi) difference from the other two, a performance fault is set against that sensor.
    BARO/Supercharger Inlet Pressure Sensor rationality diagnostic check:
    • The Supercharger Inlet Pressure Sensor signal is compared to the BARO signal to check rationality of the sensors. During natural aspiration, the Supercharger Inlet Pressure Sensor signal cannot be greater than the BARO signal plus 10.3 kPa (1.49 psi). During boost conditions, the Supercharger Inlet Pressure Sensor signal and BARO signal pressures should be similar. If the diagnostic fails during a drive cycle, a fault is set (P0069) and the secondary Supercharger Inlet Pressure Sensor rationality diagnostic is run to determine which sensor is irrational.
    MAF/Supercharger Inlet Pressure Sensor rationality diagnostic check:
      • This diagnostic runs continuously, unless any airflow, throttle, MAF, BARO, or Supercharger Inlet Pressure Sensor diagnostics have failed. Then using the pressure differential across the throttle opening (BARO - Supercharger Inlet Pressure Sensor), the PCM models the mass air flow volume through the Throttle Body. This modeled value is compared to the actual MAF Sensor signal input to the PCM. If the difference is greater than a calibrated threshold, a fault is set (P1613) and the secondary Supercharger Inlet Pressure Sensor rationality diagnostic is run to determine which sensor is irrational.
    • If either of the first two diagnostics fail during a given trip, or if one of the downstream MAP/Pressure Sensors is determined to be irrational, the PCM runs a secondary diagnostic to determine if the Supercharger Inlet Pressure Sensor is rational. With the engine in a natural aspiration condition (not boosted), the PCM compares the signal input from the Supercharger Inlet Pressure Sensor to the signal inputs from the Supercharger Outlet Pressure Sensor, Bank 1 MAP, and Bank 2 MAP Sensors. If the Supercharger Inlet Pressure Sensor is not within a calibrated threshold of the other three MAP/Pressure Sensors, it is determined to be irrational and a fault is set (P121B).
    Temperature sensor rationality checks:
      • After a cold soak of the engine, the Engine Coolant Temperature (ECT) and Ambient Air Temperature (AAT) Sensor inputs are compared to the inputs form each of the temperature sensors located in the MAF and MAP Sensors. If a temperature sensor is not within a calibrated threshold of the ECT or AAT Sensors, a performance fault is set.
    [paste:font size="4"]When Monitored and Set Conditions
    When Monitored:
    [/paste:font]
    • This diagnostic runs continuously with the engine running.
    Set Conditions:
      • During natural aspiration operation the Supercharger Inlet Pressure Sensor reading is greater that the BARO reading plus 10.3 kPa (1.49 psi), or during boost operation the Supercharger Inlet Pressure Sensor is not within 15 kPa (2.18 psi) of the BARO reading.
    Default Actions:
    • The MIL light will illuminate.
    • Boost is disabled.
    Possible Causes
    SUPERCHARGER BYPASS VALVE STICKING OR INTERMITTENT ELECTRICAL CONNECTION
    THROTTLE BODY STICKING OR INTERMITTENT ELECTRICAL CONNECTION
    SUPERCHARGER INLET PRESSURE SENSOR OUT OF RANGE
    BARO SENSOR OUT OF RANGE
    Always perform the PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
    Diagnostic Test
    1.CHECK FOR AN ACTIVE DTC
    NOTE: Diagnose and repair any 5-Volt Reference High or Low DTCs before continuing with this test procedure.
    1. Start the engine and allow it to idle.
    2. With the scan tool, read DTCs and record on the repair order.
    Is the DTC active or pending?
    Yes
    No
    2. CHECK THE SUPERCHARGER BYPASS VALVE FOR BINDING/STICKING/INTERMITTENT CONNECTION
    1. Turn the ignition off.
    2. Check the Supercharger Bypass Valve for a physical or mechanical obstruction.
    3. Disconnect the Supercharger Bypass Valve harness connector and check the terminals for loose fit, corrosion, or pushed out terminals causing an intermittent connection.
    Were any problems found?
    Yes
    No
    3. CHECK THE THROTTLE BODY FOR BINDING/STICKING/INTERMITTENT CONNECTION
    1. Check the Throttle Body for a physical or mechanical obstruction.
    2. Disconnect the Throttle Body harness connector and check the terminals for loose fit, corrosion, or pushed out terminals causing an intermittent connection.
    Yes
    No
    4. CHECK THE SUPERCHARGER INLET PRESSURE SENSOR
    1. Turn the ignition on.
    2. With the scan tool, view the Supercharger Inlet Pressure Sensor reading.
    3. With the scan tool, view the other three MAP/Pressure Sensor readings.
    Is the Supercharger Inlet Pressure Sensor reading within 5.0 kPa (0.725 psi) of the other three MAP/Pressure Sensors?
    Yes
    No
    • Useful Useful x 4
  12. B5 Blue
    1,745
    Good stuff
  13. CO Springs Sublime Kitty
    Apr 2, 2015
    203
    125
    Well that's not really helpful, thanks.
    • Funny Funny x 2
  14. CO Springs Sublime Kitty
    Apr 2, 2015
    203
    125
    Wow, that was a bit above my technical ability. Do you have a cliff notes version? Lol. Thank you for the info! I am going to bring that in with me tomorrow when I have my service department look it over. Dr. Buick, the check engine light was off just a minute ago when I went to the store. But the code was saved in diagnostics.
  15. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,383
    768
    Slinger Wisconsin
    DO NOT take that in with you Please.I will not be posting anymore of those than.
2015 dodge charger malfunction light
2016 challenger hellcat check engine light codes
check engine light hellcat challenger
clearing 2012 dodge challenger check engine light
dodge challenger throttle light pkus check engine
dodge hellcat p1613
p0069 on supercharger
