Chrysler announces big Charger recall-handing out wheel chocks to fix
Discussion in 'Dodge Charger SRT Hellcat' started by m5biemer, Feb 3, 2016.
  1. m5biemer
    m5biemer Silver Member
    Sep 10, 2015
    172
    26
    First Coast
    WTF is with that? Seems like the chassis has too much flex when you use the jack? I hope someone here more knowledgeable than me can explain this and why we shouldn't be worried. Hope I'm not overreacting but I'm ready to cancel my order and get a Challenger. I'm not planning on trying to to over 200 mph but still.......
  2. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    To some degree, flex has always been an issue with the new frames as far back as 08 in the Chall, charger and 300.
    I put sub frame connectors in all 3 of my Challengers to help with some of it
  3. BULL
    Nov 20, 2014
    3,803
    1,304
  4. Dragon
    Dragon Gold Member
    Oct 16, 2014
    658
    230
    AZ
    is this wheel choke a block you are to put under the wheel when you change your tire?
  5. ChargerChallenger
    ChargerChallenger Gold Member
    Apr 25, 2015
    530
    335
    513
    Correct it is and just common sense when jacking a vehicle it's always wise to chalk a tire. Not a big deal and probably a good thing to have a heads up of common sense.
  6. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,460
    768
    Yup, Jacking 101, always use chalks. 2x4's work well too.
  7. toasteroven
    toasteroven Silver Member
    Feb 13, 2015
    229
    75
    Canadian, 300 SRT392
    You shouldn't be worried. You are overreacting.
    The manual specifically says to block / chock the wheels when jacking, and clearly outlines the proper jack points.
    This recall is for owners who are too stupid to use common sense, let alone read the manual or be allowed to reproduce, and then blame the resulting upside-down-Charger on the manufacturer.
    • Agree Agree x 3
  8. Hb hellcat
    Hb hellcat Black Betty...BamAlam!!!
    Feb 14, 2015
    611
    201
    Sunny Southern California
    I guess that answers the question of whether I need to stiffen the chassis for road racing this beast!
  9. 4510
    May 13, 2015
    754
    171
    Arizona
    What color chalk do you use? Regular white or the pastel colors?
    • Funny Funny x 1
  10. Hammer Down
    Hammer Down Gold Member
    Jan 11, 2016
    427
    273
    South Jersey
    What else would you use? Sidewalk chalk. Cmon. No brainer. Regular crime scene white.
  11. Jim M
    Jim M SRT Hellcat Supporter Gold Supporting Member
    Jan 12, 2015
    623
    217
    Oviedo, FL
    I've always used 4 x 4's for chocks and have always chocked. Funny thing, my '56 Chrysler (and many other earlier Mopars) came from the factory with a black wooden wheel chock in the trunk.
  12. Hammer Down
    Jan 11, 2016
    427
    273
    South Jersey
    And this really shouldn't have to be said, but it does, usually. If you will be crawling under your car or if you will have it jacked up for an extended period of time, use ramps or jack stands. Don't crawl under there while its only on a jack. And if you walk away from it, make it safe. Shouldn't need to say that. If you are not going under and just doing a tire rotate jack is fine. Just keep your legs out from underneath. And yes, chock a wheel in either application. That is all.
  13. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,498
    483
    408
    The Boonies
    [​IMG]
    • Funny Funny x 5
  14. JonWrong
    JonWrong Silver Member
    Feb 3, 2015
    358
    52
    Orlando, FL
    I have had my car up on stands numerous times without issue. This is for people who used a stock style scissor jack. If you are using a good floor jack, there is no issue. I used the ZL1 jackpads with my floor jack, and it is very stable. I am pretty anal about jacking and causing no damage. My method is to use two ZL1 pads and two jacks (one on each side) to get the front up. I then put stands on the frame rails.
    For the rear, I jack on the diff (making sure to clear the cover), and place stands under the rear jacking pucks. Bam, whole car in the air. No damage, no drama.
  15. fnkychkn
    fnkychkn Thread Killer Gold Supporting Member
    Jan 24, 2015
    1,659
    734
    633
    greasy cardboard box
    Jacking the aluminum pumpkin can distort it.
    • Agree Agree x 3
    • Funny Funny x 1
charger so3 wheel chalk recall
hellcat recalls
how to jack up 2015 charger
scissor jack failure dodge factory
scissor jack for dodge challenger hellcat
so3 wheel chocks
wheel chock recall charger
wheel chock recall dodge
