Code P2629 ??
Discussion in 'SRT Hellcat Maintenance' started by SRT HC, Aug 10, 2015.
  1. SRT HC
    SRT HC BANNED
    May 11, 2015
    879
    321
    Jacksonville, FL
    This morning after a very short burst (saw a police) and backed off quickly, then a few seconds later I threw a code P2629.
    Does anyone know what that means?
    What might the cause be?
    Thanks.
  2. Harley88
    Harley88 Gold Member
    Nov 15, 2014
    1,283
    383
  3. SRT HC
    SRT HC BANNED
    May 11, 2015
    879
    321
    Jacksonville, FL
    That doesn't sound good
    Wonder if it's reasonably safe to drive about 10 miles to dealer.
  4. Harley88
    Nov 15, 2014
    1,283
    383
    Dealer told me as long as "idiot engine light" is NOT blinking, then safe to drive. Mines in shop as I write this. --
    -Wish n u good luck!
  5. Paladin06
    Sep 3, 2014
    4,923
    2,041
    818
    San Tan Valley, AZ
    Isn't someone here tracking all these code Top Cat
    How many miles? Good luck.
  6. B5 Blue
    1,745
    I thought you were:confused:
    • Funny Funny x 2
  7. Paladin06
    Sep 3, 2014
    4,923
    2,041
    818
    San Tan Valley, AZ
    I been a little under the weather. Not doing much of anything lately.:(
  8. B5 Blue
    1,745
    Sorry to hear that, now get back to work Slacker:D
    • Funny Funny x 2
  9. Paladin06
    Sep 3, 2014
    4,923
    2,041
    818
    San Tan Valley, AZ
    Is that anyway to talk to a brother Knob?
    • Funny Funny x 1
  10. SRT HC
    SRT HC BANNED
    May 11, 2015
    879
    321
    Jacksonville, FL
    Hellcat has about 2,600 miles.
    Now for some conflicting information:
    Took to dealer. P2629 cleared when I got to the dealer, but CEL was still on. Dealer scanned and told me it was an O2 sensor problem. Safe to drive home. so I made an appointment for next Wednesday to recheck CEL and fix rear door lock (been malfunctioning since I have had car).
    Left dealer and P2629 reappeared when I checked diagnostics again. A very short time later (about 0.5 miles) I rechecked diagnostics and the P2629 had gone away. CEL still on and stayed on until I turned car off in driveway.
  11. SRT HC
    SRT HC BANNED
    May 11, 2015
    879
    321
    Jacksonville, FL
    Went to the gym about 5 miles from my house.
    Turned on car: CEL ding and Light stayed on. Diagnostics showed P2629. Drove about 100 yards and Diagnostics show no codes, but CEL still lit.
    After about 45 minutes at gym I returned home. The exact same sequence of events
  12. Paladin06
    Sep 3, 2014
    4,923
    2,041
    818
    San Tan Valley, AZ
    I got a CEL and a code because I turned to the switch to run with the MAF disconnected. Once I drove the car the code cleared but the CEL stayed on. I had the dealer clear the CEL and all has been well every since.
  13. fnkychkn
    Jan 24, 2015
    1,605
    696
    greasy cardboard box
    From FSM
    P2629-O2 SENSOR 2/1 PUMP CELL CURRENT TRIM CIRCUIT/OPEN
    Theory of Operation
    The wide-band O2 Sensor operates differently than traditional O2 Sensors. The wide-band O2 Sensor tip consists of two cells that provide different functions, a measurement chamber and a detection chamber with pumping capabilities. The oxygen pumping function is the ability to pump oxygen into or out of the measurement chamber depending on the level of oxygen in the measurement chamber. This function provides the wide-band sensing capabilities and is critical for proper oxygen measurement. The O2 Sensor Reference circuit provides a common bias supply to both the O2 Sensor Signal and the O2 Sensor Pump Cell Current circuits.
    During normal operation, the O2 Sensor Reference voltage and O2 Sensor Signal voltage will be a fixed voltage value. The O2 Sensor Current Pump voltage will switch from between 0.45 volts above and below the fixed O2 Sensor Return voltage, allowing current to flow in either direction through the pump. This correlates with the pumping of oxygen into and out of the measurement chamber. On a properly operating vehicle, this happens very quickly and the voltage reading should maintain a steady 0.45 volts when taking a voltage measurement between the O2 Sensor Signal circuit and the O2 Sensor Reference circuit of the O2 Sensor with the engine running and the O2 Sensor operating in closed loop.
    When the exhaust stream has a lean air/fuel ratio (high oxygen content) the pumping element voltage will move toward +0.45 volts pumping oxygen out of the measurement chamber. When the exhaust stream has a rich air/fuel ratio (relatively low oxygen content) the pumping element voltage will move toward -0.45 volts pumping oxygen into the measurement chamber.
    When Monitored: This diagnostic runs when the following conditions are met:
    With the ignition on
    The O2 Sensor 2/1 at operating temperature
    The pump cell active
    Set Conditions:
    The Powertrain Control Module (PCM) detects an open on the O2 1/1 Pump Cell Current Trim circuit.
    Default Actions:
    MIL is illuminated on the second consecutive trip that the diagnostic fails.
    Possible Causes
    O2 1/1 PUMP CELL CURRENT TRIM CIRCUIT OPEN OR HIGH RESISTANCE
    O2 SENSOR 2/1
    POWERTRAIN CONTROL MODULE (PCM)
  14. B5 Blue
    1,745
  15. Gallitos98
    Gallitos98 Active Hellcat Member
    Aug 30, 2015
    106
    36
    28
    My car is without the catalistycs and using HP tuner but the P2629 code show up.
    Any reason Why???
2015 challenger srt 02 sensor wideband from factory
dodge hell cat code p2629
p2629
