considering rear tire change only?
Discussion in 'Dodge Challenger SRT Hellcat' started by huggytree, Feb 16, 2015.
  1. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,149
    752
    628
    since i have the summer tires and didnt really want them i am considering changing the rear tires
    #1 i would like to leave the fronts alone and use the existing rear tires someday on the fronts...can i do that?
    #2 is mixing and matching tires not a good idea? im not doing any road course with the car...only straight line all out stuff
    #3 what size for the rear?
    #4 what is brand/model is recommended for WI?
    i dont think it even hit 90 degrees last summer.......i park my gt500 w/ F1's early because the tires suck when its 40-50 degrees......i always kept driving my 2011 SRT with RSA's until it snowed (mid nov)....never had an issue in 40 degree weather....yea the tires spun a bit more, but nothing scary or uncontrollable......i want a tire that i can use in 40 degree weather and play around with power to some degree......my gt500 and f1's are out right dangerous at 40 degrees and i assume the P0's on the HC will be the same....
    do 305's fit on the rear?
  2. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,836
    1,332
    933
    Kenosha, Wisconsin
    305s fit.. but recommended for a 10" rim.. plenty here have already mounted drag radials in the 305 on the stock rims... I will be doing the same in a month or so..
    1st choice are the Mickey Thompson drag radials...
    Distant second are the Nitto 555 drag radials..
    From my experience with both.
    • Useful Useful x 2
  3. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,383
    768
    Slinger Wisconsin
    How about I trade you all of my all seasons
  4. huggytree
    Nov 22, 2014
    3,149
    752
    628
    id consider the trade, but i really want wide on the back......if it came stock w/ 305's i would swap in a heart beat
  5. huggytree
    Nov 22, 2014
    3,149
    752
    628
    MT drag radials will work in 40 degrees? what if i get caught in occasional rain? (i try not to but it most likely will happen at some point)
    im not going to drag strip the car.....just the street....i occasionally want to floor it and not smoke the tires or slide off the road....i may try a drag strip at some point......
    i dont want to pass a prius hard core and slide off the road in the process....i want something that will stick in WI 40 degrees to 90 degrees
    • Funny Funny x 1
  6. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,682
    2,034
    I'm going to throw don't nitto 555 on the rear, I won't be driving year round
  7. StellasHC
    Nov 18, 2014
    1,836
    1,332
    933
    Kenosha, Wisconsin
    My old Nitto 555s did well in the rain.. and cold... but really wouldnt hook a 590rwhp car on the street..
    Kind of a trade off for you.. if you want to drove in the cold and rain, you are going to have to sacrifice in other areas..dry traction may be one of them..
  8. hellcat1
    Sep 27, 2014
    10,682
    2,034
    What do you suggest then
  9. huggytree
    Nov 22, 2014
    3,149
    752
    628
    rain will be rare if ever...
    cold yes, dry yes
    nitto 555's have been suggested
    my f1's on the gt500 are dangerous under 60 degrees.....i just dont want the same experience in my HC
    my f1's are really garbage unless its 85 degrees out or better.....not sure if the P0's are any better?
    at 50-60 degrees can i floor nitto 555's at 50 mph and stick to the ground?
  10. StellasHC
    Nov 18, 2014
    1,836
    1,332
    933
    Kenosha, Wisconsin
    I honestly, IMO,would just stay with the factory tires vs. Spending 700 on the 555s. Ive had them on 2 other cars,making less power tgan the HellCat, and I promised myself that I would never buy them again... they just dont hook on the street, and require excellent prep to hook at the track.
    For me, its the Mickey Thompson drag radial or stock for a street tire...
  11. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,383
    768
    Slinger Wisconsin
    Just drove my car home it's 16 degrees out. the MT hooked very well for the crap on the roads straight as a arrow.
  12. Blackdevil77
    Blackdevil77 Silver Member
    Feb 1, 2015
    538
    132
    Long Island, New York
    You can give the Michelin Pilot Super Sports a try. I know they aren't a drag radial, but you can get them a bit wider than stock, they SHOULD grip a little better than the factory tires according to the reviews, and they're much safer in the cooler weather. If you want something more aggressive, you can try the Toyo R888's, but the Michelins would probably be better in the cold. Honestly, the P-Zero's are pretty good street tires.
  13. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
    Are you keeping the factory rims?
  14. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,383
    768
    Slinger Wisconsin
    If i sell it they go with, I have a set of HRE's being made
  15. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
    What price can you get HRE for?
    What model?
2015 hellcats modifying the back tired
hellcat uncontrollable
just chabging rear tires on gt500
