Controlled Exhaust Valve Interrupt Override
Discussion in 'SRT Hellcat General Discussions' started by TallCool1, Feb 28, 2015.
  1. TallCool1
    2,436
    825
    Pacific NW
    What features wanted?
    Taking over control no error codes looks like will easy.
    Override (open/close) easy looks like can do interrupt at fuse block. Simple circuit design installed there.
    But I was thinking features might be wanted, like rpm thresholds, accelerator set points, etc.
    Gonna build override interrupt 1st. What else would people like to see?
    • Like Like x 3
  2. TallCool1
    2,436
    825
    Pacific NW
    Well, manual control of exhaust valves (open / close at will, no error codes) DONE! Requires solid state relay, a switch and some simple wiring, and a couple of other parts easily sourced.
    Operation: switch override on, valves open. Switch override off, valve control returns to car.
    Before I provide details, pics etc, humble support request. I need to source two of the valve assemblies. The support I am seeking:
    Can anyone get 2 valve assemblies to me at dealer cost? And if I keep only 1 of them, could I return the other and receive a refund it wouldn't be used? I will pay s&h, including if I return one. I would return it within 30 days of receipt, if it does go back.
    (I may find an existing switch to relieve the need for install before sharing all...)
    Thanks much.
    • Like Like x 3
  3. TallCool1
    2,436
    825
    Pacific NW
    (Above is phase 1 design. Phase 2 would be same except all solid state done with circuit / resettable fuse package that will plug into fuse assy. Control would then be by switch (installed but that's more wiring, or, by using 1 or 2 existing switches. If one it would be a momentary switch, held longer than normal, or 2 pressed at same time.). Phase 3 would be Bluetooth addressable, essentially faking out the radio then providing control there. The idea theme is to remove the need for switch install, and get this plug and play, as a simple feature for those that like noise. No comments on impacts to car performance that's not my bag I don't have enough knowledge to say this is a good or bad idea that way...)
    • Useful Useful x 2
  4. magnummrk
    magnummrk Platinum Member
    Sep 30, 2014
    3,826
    1,113
    918
    Wisconsin
    This sounds good!
    Would like to be able to control the valves
  5. jim
    jim Silver Member
    Sep 22, 2014
    482
    223
    Mchenry Illinois
    i want mine quiet. i would like to keep it shut.
  6. ljaviation
    ljaviation Self proclaimed Banned, Because I can.
    Feb 10, 2015
    656
    246
    Asheboro, NC
    Find a wrecked one beyond repair that's already for scrap. Offer a $. Should be cheaper than new.
    L J
  7. fnkychkn
    Jan 24, 2015
    1,542
    646
    greasy cardboard box
    right actuator P/N 68230108AE $441.00 CAD
    left actuator P/N 68239269AE $441.00 CAD
    I can get you the parts at my cost but the shipping would be high and I cannot take them back.
  8. Chippy
    Chippy Silver Member
    Nov 27, 2014
    656
    140
    Alberta
    Tallcool1 thx for posting as I had talked about putting a switch on the actuators long ago somewhere here!!! Wish I could help. There's most likely a switch on this car that can be used with a relay and a momentary power timer to not need to put in an aftermarket switch. Although most probably don't need fancy hide a nice little toggle easy
  9. TallCool1
    2,436
    825
    Pacific NW
    Does that include the smart controls or is it you replace as assy? Also when you replaace do you need to flash ecm at change (can I get a copy of just the procedure steps?) Also is that your cost or retail?
  10. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    Tallcool1 to bad you can't get in the computer and change when it calls for them to be open
  11. TallCool1
    2,436
    825
    Pacific NW
    In essance you will (ecm won't know.) A few ways to do this.
  12. hellcat1
    Sep 27, 2014
    10,672
    2,033
    I look , and other look forward to your progress
  13. TallCool1
    2,436
    825
    Pacific NW
    Any existing switch can work haven't spent time on that but the ones I hand in mind might be the garage door ones. But not having wiring or schematics or layouts is a slow deal using them so figured do it with an installed switch then go that route or BT to the HK system may just be as fast but increases cost. Wheel control would be great but limits there without affecting more often used functions. Maybe the ok or cancel switch dunno not focused there 1st.
  14. B5 Blue
    1,745
    Those ain't cheap:(
  15. TallCool1
    2,436
    825
    Pacific NW
    Dude I mean come on ca Ching $$$ :( just need for testing too sucks but maybe I could only have to keep one need both validate function since their each addressed differently. I can't burn anymore free time at my dealers shop becoming a fixture and bribes only go for so long...
2015 dodge challenger hell cat code p121b
2015 dodge charger srt 392 y pipe shut off
68239269ae
exhaust trouble codes for 2016 challenger
p121b challenger
p121b code scat pack
p121b dodge
wht is code p1217 on 2015 callenger srt
