Cost of installing epoxy floor
Discussion in 'General Automotive Discussion' started by sharkysharp, Nov 4, 2015.
  1. sharkysharp
    sharkysharp Rookie
    Nov 4, 2015
    1
    0
    1
    HI people, since few days I'm thinking to renovate my garage floors. I had just abandoned the idea of trying to paint my concrete garage floor. My mother is suggesting me to consider epoxy garage floor. Has anyone out here ever tried epoxy floor coating. I'm planning to call a Toronto based floor contractors - Proseal Floor within two days, Prior I make the call I would like to know what will the cost of installing epoxy floor with chess board design? Any ideas?
  2. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,909
    1,330
    498
    Virginia
    Epoxy garage kits are out there and work well. Like most things, preparation (cleaning and etching) is the key. Good buddy in CA did his and it came out great but he followed the directions to the T. But in the end he got a great product.
    Most kits have color flake additives to add some spice to the look. Lots of options out there.
  3. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    134
    Ontario
    I did mine with Concrete finishes (based out of Windsor)
    They did a great job and I anm happy with the results, 20x20 garage about 2K, guaranteed for life
    They grind the floors, fill in cracks and then epoxy with clearcoat and anti-slip, any finish you want
    makes a huge difference
  4. Rham
    Rham Senior Hellcat Member Hellcat Car Club
    Oct 21, 2015
    129
    98
    image.jpeg I'm actually getting my floors done next Monday. The grinding with the diamond sander is essential to the proper adhesion of the epoxy so you don't get hot tire lift. Buying the stuff from home deposit without the proper prep might be a waste of money. Zippy's comments are spot on, my garage is 21x23 and will cost 1,750. Pic is what it will look like when completed
  5. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    I used a two part system a number of years ago, holds up well, lots of prep needed but it does work.
  6. Wamo
    Wamo Senior Hellcat Member
    Oct 20, 2014
    123
    46
    Houston
    Mine is actually getting done as I type. I didn't do it myself because of the prep. Prep is everything. My garage floor is about 8 years old and has a couple oil spots and I didn't trust myself enough to do it right. They used a grinder and bead blaster and fixed a couple hairline cracks
  7. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
    There a lot of good products out there. The only thing that j will say is check for ground pressure ( moisture) through the concret. Duck tape a two foot by two foot pice of plastic down and let it sit for two days . If when you pull it up it is dry you should be ok To coat with quality product. On a side note I have seen some nice stand and polished floor . And with them you don't have to worry about the coating coming up.
  8. Rham
    Oct 21, 2015
    129
    98
    Here's a pic of hot tire lift from my 2014 Corvette. The garage floor paint was melted to the tires, I couldn't get it off. Now that I have the Hellcat, it's time to fix the garage floor properly image.jpeg
  9. badash
    badash Silver Member
    Jan 2, 2015
    386
    105
    Who did you use? my house will be don't in a couple months and want to get it done. Im here in houston as well.
  10. Toolman_42
    Jan 26, 2015
    2,909
    1,330
    498
    Virginia
    prep, prep, prep. not an easy task to get it done right.
    besides the diamond grinders there are acid washes that will etch the concrete to properly prep the floor.
  11. Slowhand
    Slowhand Gold Member
    Jan 26, 2015
    606
    265
    Maryland by the bay
    Last house I did mine myself with UCoat with UGloss AF - UCoat It Epoxy Floor Coating. Rented a grinder for 1/2 day,leafblower to clear the dust after sweeping it, diluted muratic acid to etch it. Then two coats plus a top coat. Did it over 3 days. Not hard, spent $700 for a 24x27 garage.
  12. TallCool1
    2,439
    829
    Pacific NW
    Agree do it yourself, day job save the $$$ for something else.
  13. Wamo
    Oct 20, 2014
    123
    46
    Houston
    Epoxysolutions. I think they did a very good job
  14. specl4ss
    specl4ss Gold Member
    Jul 9, 2015
    598
    600
    568
    Wyoming
    There is a lot of prep to a epoxy floor, My garage was only 2 years old when I decided to do it, but it's worth it, I like it, image.jpg
  15. B5Blue6M
    B5Blue6M Active Hellcat Member
    Sep 27, 2015
    104
    34
    28
    Minnesota
    [GALLERY=][/GALLERY]Don't do epoxy. It will eventually peel, and even when new does not look good as polyurethane. Polyurethane guaranteed 15 years, glad I did mine. Huge improvement. Sorry these are pre-hellcat pics lol.
car tires on garage floor
epoxy floor coating forum
epoxy flooring forums
