CQuartz & Accessories
Discussion in 'SRT Hellcat Detailing' started by DataZombies, Aug 3, 2015.
  1. DataZombies
    DataZombies Hellcat Member
    Jul 19, 2015
    30
    10
    I'm planning on adding door sill guards and moulded splash guards to my HC Challenger when it arrives. Should those be attached before or after CQuartz?
    When they apply the CQ stuff do they do the door, trunk and hood sills?
  2. C. Charles Hahn
    C. Charles Hahn Silver Member Hellcat Supporting Vendor
    Jan 6, 2015
    103
    61
    168
    Lansing, MI
    As long as the parts you're installing aren't held on by 3M trim tape or other adhesives, you should be fine waiting to install them after CQuartz is applied. If they are adhesive-mounted, I would recommend installing them before the coating to prevent any adhesion issues.
    You will want to check with your particular installer regarding the coating being applied to the sills/jamb areas, as some do and others don't.
    Hope this helps!
