CQUARTZ FINEST
Discussion in 'SRT Hellcat Appearance' started by magnummrk, Feb 5, 2015.
  1. magnummrk
    magnummrk Platinum Member
    Sep 30, 2014
    3,826
    1,113
    918
    Wisconsin
    Anyone have a vehicle treated with this?
    I just got my quote and wanted to hear from someone that said it was worth it.
    Shocked it took 3 days to complete
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,032
    I got a quote for 425..
  3. magnummrk
    Sep 30, 2014
    3,826
    1,113
    918
    Wisconsin
    My quote was higher than that, but he is doing more than just the CQuartz
    I just was hoping to find someone who had it done and get there true life experience with it
  4. bfusion
    bfusion Gold Member
    Sep 19, 2014
    2,389
    818
    1 day to apply the CQuartz, 2 days of burnouts and cruising through the drive throughs spilling tartar sauce and leaving fish dicks under your seat:D
    • Funny Funny x 9
  5. magnummrk
    Sep 30, 2014
    3,826
    1,113
    918
    Wisconsin
    Pardon me?!
    • Funny Funny x 5
  6. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    70.196059, -148.559760
    I think he is being funny. Trying to say it will take the guy one day to apply the stuff to your car, then he will drive your car around for two days beating the snot out of it before you come back to pick it up....
  7. bfusion
    bfusion Gold Member
    Sep 19, 2014
    2,389
    818
    I know it's sticks, but who really knows what's in those things! sounds like dicks
    • Funny Funny x 3
  8. bfusion
    bfusion Gold Member
    Sep 19, 2014
    2,389
    818
    Sometimes I crack myself up, even if I'm the only one laughingo_O
    • Funny Funny x 4
  9. magnummrk
    Sep 30, 2014
    3,826
    1,113
    918
    Wisconsin
    Oh I laughed! :D
    Just figured you slipped from the S to the D
    • Funny Funny x 1
  10. magnummrk
    Sep 30, 2014
    3,826
    1,113
    918
    Wisconsin
    This is what the guy is including...seems like a pretty good job
    Included Services
    1. Tires are scrubbed with a degreasing agent to remove all dirt, road grime, and previously applied dressings.
    2. Wheel faces, inner barrels, and lug nuts are deep cleaned and decontaminated using a pH neutral solution and a variety of task specific brushes.
    3. Wheel wells are cleaned, degreased, rinsed, and treated with a conditioner to ease future cleaning.
    4. Bug remains, tar, and road grime is treated with a strong, yet paint friendly cleanser.
    5. A one step paint decontamination safely removes embedded iron particles.
    6. License plates removed, for a more thorough cleaning.
    7. The vehicle is foamed with a gentle citrus degreaser to help loosen and encapsulate dirt, and to remove any oils or waxes.
    8. A proper full vehicle two bucket hand wash is performed using a pH neutral high lubricity shampoo, and then fully rinsed.
    9. Vehicle is dried with plush premium microfiber drying towels, and a forced air blower to remove trapped water from tight spaces.
    10. A claybar and lubricant are used to remove embedded contamination from the surface, completing the decontamination process.
    11. Glass surfaces are cleaned of dirt and grime, a claybar is used to remove bonded contaminants.
    12. Paint work is carefully inspected using a variety of high output lights to assess surface condition.
    13. Vehicle paint is measured for thickness and uniformity using an electronic paint thickness gauge. This is necessary to ensure that the polishing process can be safely completed without compromising the paint surface.
    14. All sensitive plastic, rubber, and vinyl trim is masked off to protect it from damage during the polishing process.
    15. Two stage paintwork correction process is used to permanently remove oxidation, towel marks, holograms, water spots, moderate swirls, and light scratches. This will drastically improve the gloss and paint clarity, but is not sufficient to remove the deepest paint defects or scratches. The products used during this step will vary and are dialed in to create the best results on your specific vehicle’s finish. Note: In some cases, deeper defects may require a Stage Three detail to be completely removed.
    16. Polycarbonate headlight and taillights lenses are polished to remove light swirls, improving gloss and shine.
    17. The surface is wiped then wiped down with an alcohol based surface prep to remove any residual polishing oils. This improves the longevity of the applied paint sealant.
    18. Three thick coats of CQuartz Finest is applied to the paint surface. Creating a super hydrophobic surface that resists dust, dirt, water, fine swirls, bird droppings, bug residue, and strong chemical cleaners. Warrantied durability for at least two years after application, with proper maintenance.
    19. All plastic, rubber, and vinyl trim is cleaned and then treated with an extremely durable trim coating that lasts up to two years, and leaves a “like new” appearance.
    20. Exterior glass surfaces are cleaned to a streak free finish.
    21. Metal trim and exhaust tips are cleaned of carbon build up, polished by hand, and protected with a high temperature resistant metal coating that lasts up to two years.
    22. Tires are dressed with a low gloss water based protectant for a fresh, natural look.
    23. Wheels are finely cleaned with an alcohol based surface prep, then protected from brake dust and road grime with a glossy high temperature wheel coating that lasts up to two years, making wheel cleaning incredibly easy.
  11. bfusion
    bfusion Gold Member
    Sep 19, 2014
    2,389
    818
  12. Rob K
    Rob K Gold Member
    Nov 22, 2014
    572
    483
    513
    Outside Philly
    I thought it was over $1,000 for Quartz finest application.
  13. magnummrk
    Sep 30, 2014
    3,826
    1,113
    918
    Wisconsin
    Close to it :eek:
  14. Dubya
    Dubya Silver Member
    Jan 3, 2015
    717
    202
    Thanks Kanye, now I've got that South Park episode running through my head.:eek:
  15. Odin
    Odin Gold Member
    Jan 9, 2015
    196
    128
    Pennsylvania
    Based on these services provided he is properly preparing the paint for application. Yes, 3 days is about right because of the prep work (clay, 2-step polish etc) and the curing of the CQuartz Finest. A proper paint prep is key in the longevity of the CQuartz Finest ( 2 year limited warranty). In addition, the installer has to be an authorized dealer of CQuartz Finest. The product is not available for sale to the general public. Prices may vary depending on the market you live in. If your detailer is good and has experience (which it sounds like he does) then I would expect $800-$1200.
    Is your Hellcat going to be a daily driver?
    Is it garaged?
    Will you drive it in the winter or bad weather?
    Do you like to detail your cars?
    Has your detailer discussed other options of protection (waxes/sealants)? This includes protecting your wheels, glass, plastic, lights, etc.
    CQuartz Finest is good product but expensive. If your detailer is reputable he will answer all your questions honestly and help fit his services to your needs.
    Let us know what you decide.
applying cquartz
cquartz finest application costs
cquartz finest application procedure
cquartz finest for sale
cquartz finest mechanicsburg pa
cquartz installers in pennsylvania
finely cleaned forum
