Default Mode
Discussion in 'SRT Hellcat General Discussions' started by Kevin M, Mar 17, 2015.
  1. Kevin M
    Kevin M Silver Member
    Sep 18, 2014
    335
    123
    Detroit, Mich
    Is there any way to have the car start in another mode other that Default, or can we at least modify the settings in default mode so that they stay that way?
  2. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,515
    1,434
    818
    Endless Mtns of Pa
    if you hit SRT button twice it puts you right into custom mode
  3. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,461
    768
    Abe,
    You beat me to it, yup, no other way (that I know of)
  4. tsc
    tsc SRT Hellcat Enthusiast
    Oct 27, 2014
    1,536
    751
    563
    Cincinnati, OH
    No way to change that currently. Car will always start in Default mode, regardless of what drive mode you last used. Only exceptions are ECO and Valet Modes. Those stick on next startup and until turned off.
    Speaking of default mode I am having some odd behavior since yesterday afternoon. Normally you cannot change traction control or transmission mode settings in Default, only paddles and suspension. Traction control can be changed in any mode, including Default, by using the traction control button.
    Now the odd thing that is happening.. If I go to any non-Default mode and then back to Default, no matter what the traction control was previously set to Default sets traction control to Sport instead of Street. In normal operation it would go back to Street traction control.
    Have not been able to get around this and each time I go back to Default I must manually cycle back to Street via the button.
  5. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    All thunders have been taken so now I have no solution LOL great job guys
  6. Tammie
    Sep 11, 2014
    13,564
    4,650
    1,223
    Washington
    Did you hold that mode down for 5 seconds while csra was stopped? That's what I had to do. Mine kept defaulting to track mode until I held the street mode down. Don't know if it was just a glitch with mine but no problems since I did that.
  7. tsc
    Oct 27, 2014
    1,536
    751
    563
    Cincinnati, OH
    That's the thing.. In the Default Mode Setup screen you can't even change the traction control setting. Traction control can only be changed in default mode via the button. If you try to change it in the setup screen it will tell you it can't be changed and to switch to Custom mode for changes. I'll mess around with holding the existing Street setting and see if that helps.
  8. tsc
    Oct 27, 2014
    1,536
    751
    563
    Cincinnati, OH
    Well, wouldn't you know it.. I went into Default Mode Setup, held down the Traction Control 'Street' button (the only one that can be selected), exited Setup, power cycled the vehicle and it appears to now work as intended. Odd bug. I did take a video of the bug beforehand, for those curious:
    • Useful Useful x 2
  9. Tammie
    Sep 11, 2014
    13,564
    4,650
    1,223
    Washington
    Excellent. I thought it was odd myself. I was just glad to finally get my default back to street. I swear I was going to break a tooth stuck in track mode on some of the crappy roads I drive! :)
    • Funny Funny x 1
  10. RoyG
    RoyG Silver Member
    Sep 18, 2014
    397
    170
    Landenberg, PA
    Thank you tsc - I have exactly this same problem! I will try your fix tomorrow, but so far you have a 100% track record so have every faith this will work!
  11. tsc
    Oct 27, 2014
    1,536
    751
    563
    Cincinnati, OH
    Should (hopefully) work the same on the Charger. Let me know how it goes. The weird part is it just suddenly started doing it... 3700+ miles of it working fine and then on the way home yesterday it decides to act as it did in the video.
    BTW, I had only turned the ignition to 'RUN' without actually starting the car. Shot the video, then held the 'Street' button in Setup, exited Setup, turned car off, opened door, closed door, put ignition back to 'RUN' again without starting car and checked and it was working as it should. When I left work later in the day it continued to act normal.
defaultmode on srt
