Default Setting Changed
Discussion in 'SRT Hellcat General Discussions' started by jmlibby, Aug 25, 2015.
  1. jmlibby
    jmlibby Hellcat Member
    Feb 11, 2015
    35
    14
    My default is now track suspension and track traction. Anyone have this happen or know the fix? I'm used to going like hell and don't want to find the hard way because it's in this setting. Thanks!
  2. MrBigKid
    MrBigKid BANNED
    Nov 29, 2014
    1,341
    409
    278
    Columbia, SC
    Never heard of this. Perhaps reloading the last update will return it to factory defaults?
  3. 06SRT10NR
    06SRT10NR The K.N.O.B. Rules Hellcat Car Club HCC Charter Member
    Nov 9, 2014
    74
    Team Hellcat GA
    had that happen after the fuel rail recall work was done. At first, I thought maybe so unreported cool update had been done, but ... I was able to make a couple changes to Default, changed traction to Sport, then tried to change the back to Track, and it of course failed. Cycled through the other modes and back to Default, no luck. Shut it down for a few minutes, started back up and Default was back to normal
  4. B5 Blue
    1,745
    Is the traction control yellow light on in cluster when in default?
  5. One Ton Racer
    One Ton Racer Silver Member
    Feb 18, 2015
    170
    55
    178
    New Brunswick, Canada
    I think I'm going to call my car Christine & hope she doesn't decide to kill me.
    She definitely has a mind of her own. She changes her custom set up quite often by herself.
    Her latest issue is an identity crisis. Sometimes, she thinks she is a 392 as the silver car comes up on the screen instead of the Red Hellcat and I only have 5 guages instead of 9 and of course no Hellcat programming available.
    Default seems to be holding so far when she wants to be a Hellcat.
    I'm going to leave it as is until just before winter lay up. I kind of get a kick out of surprises.
  6. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,005
    475
    403
    Westchester
    Had the same issue with one car start, I parked the car when i got home and started it back up remembering that i had to fix that, it was back to normal
  7. 06SRT10NR
    Nov 9, 2014
    74
    Team Hellcat GA
    B5, when my little episode hit. the traction indicator was not illuminated. if the ride hadn't been harsh, I might not have checked the settings. the traction warning and indicator did come on when I changed the settings inside Default. I wasn't too concerned about it, had a little fun changing Default to settings it isn't supposed to be able to be changed to, at least until I tried to change it back to Track and got the big FU. shutdown, waited till everything went dark, restarted, all good
  8. B5 Blue
    1,745
    If the screen snows traction is in anything other than street the light will be on in cluster, electronic snafu. I finished a 1/4 and looked at screen on return road and it showed 500 horse and all street which no way with the run I had.
  9. jmlibby
    Feb 11, 2015
    35
    14
    I'll have to check the indications when I get home, but I know the traction control light does not show. This is no bueno!
  10. 06SRT10NR
    Nov 9, 2014
    74
    Team Hellcat GA
    I've had that one twice, in Custom mode. went from 700, Sport traction, Street suspension, to 500 and all street. each time, right after a couple short WOT runs
  11. Dubya
    Dubya Silver Member
    Jan 3, 2015
    717
    202
    My default settings like to change from 700 down to 500hp. The first time it did it I accused my buddy whom I left in the car while I ran into the store. We'll it did it again the next day and several times since then. No idea what's going on, I just put it in track mode and forget about it but would love to get it acting right again.
  12. B5 Blue
    1,745
    But did it feel like 500 cuz mine wasn't
  13. Dubya
    Dubya Silver Member
    Jan 3, 2015
    717
    202
    Mine definitely went down to 500. I've still got the wrinkle lines on my face from the massive frown it caused.
  14. B5 Blue
    1,745
    For all I know mine changed to 500 after the run, didn't look until the return road
  15. ranger75
    ranger75 Silver Member
    Jan 12, 2015
    165
    54
    Yeah talked about this in another thread. Happens to mine also. 3 different cars....silver 392...red with black wheels and red with brass monkey wheels.
