Diablosport PCM Change/ Trinity 93 Octane Tune
Discussion in 'SRT Hellcat General Discussions' started by BKuz, Oct 28, 2015.
  1. BKuz
    BKuz Retired American Fighting Man
    Oct 22, 2014
    1,559
    748
    Weeki Wachee, Florida
    Have been thinking about the Diablosport PCM change out with the 93 Octane Trinity Tune. I am looking for opinions if it is worth the money and risk of voiding warranty? I think there was only a 40 hp gain. Please share your thoughts. Thank you.
    BKuz
  2. Top Cat
    Nov 26, 2014
    1,925
    1,087
    768
    Doylestown,Pa
    BK, you should see a 60-80 hp gain if tuned right, what's your intended use for the added HP?
    TC
  3. NX91Notch
    NX91Notch Gold Member
    Jan 8, 2015
    501
    249
    Seminole, FL
    I am going to probably end up using Diablo for a couple reasons. One I have used them before with no problems. 2 I already have a Trinity from my previous use with them so all I need to pay to do is the $200 send in PCM program to be able to tune. But that only gets their "canned" tunes. Which are great every day tunes and will work for most people.
    But with what Top Cat said there is probably more left in the car from a tune. Diablo plays it very very safe usually. You can use Diablo to get more out a of a custom tune though later down the road. For example if you ever install a pulley.
  4. BKuz
    Oct 22, 2014
    1,559
    748
    Top Cat,
    Is there any warranty concerns? I know I will have to put my stock PCM back in if I get service from Dodge.
    I would like the extra hp for bragging rights and also to take the car to the track.
    BKuz
  5. Rocky_Rhode
    Rocky_Rhode Senior Hellcat Member
    Oct 20, 2015
    87
    51
    Any modification, aftermarket bolt-on, or changes over factory settings you perform will risk voiding the warranty, and you should consider this with eyes wide open. Should you forget to replace your "stock" PCM prior to delivering it to the dealer for maintenance, it could void it. If you run a custom tune that damages your engine, you risk voiding it... Simple rule of thumb is to never modify, or change anything that you are not willing to accept full accountability for in the event that something goes wrong. So rather than ask others what "their" thoughts are, ask yourself if "you" are open to the possible financial consequences for "your" actions, by modifying the factory install.
    Adding an aftermarket PCM with a custom tune has a "chance" of damaging your car; only "you" can say if that "risk" is acceptable.
    Personally I will be getting a Diablo/Trinity with the unlocked PCM; I understand the risk, and am fully willing to be accountable should anything go wrong.
    • Like Like x 4
    • Agree Agree x 3
  6. Top Cat
    Nov 26, 2014
    1,925
    1,087
    768
    Doylestown,Pa
    BK
    As mentioned above I would agree, if going that route I would make sure you have a tuner experienced with the Hellcat, AJ/Hemituner &Josh @HHP, I can vouch for, there maybe some others but I can't recommend since I have no experience with them.
    TC
  7. Ray Hunsaker
    Jan 26, 2015
    624
    202
    do you guys think the tuners can some how piggy back the ecu just to keep alive the info side.. ie miles,hours,ect ?
  8. HellScoot
    Aug 20, 2015
    431
    121
    Chicagoland
    I will be curious to know if someone goes with the Diablo and replaces the PCM how that works out. I have my other car tuned but it is from Dinan and is based on the mods I made and this one keeps the BMW warranty in tact. I am sure a "generic" tune if all is stock will help but would need to be changed based on other mods you would make. I am sure there will be others with hand held tuners that can load different tunes based on mods done. No matter what you must be able to put it back to stock if you bring it in for warranty work and have not already done something else that would void your warranty. Be smart about it and you should be ok.
  9. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,274
    374
    Newport, MI
    Wouldn't the OBD II be able to tell the PCM was removed and replaced?
  10. Rocky_Rhode
    Oct 20, 2015
    87
    51
    My understanding of the 2015 PCM swap is as follows; Diablo sends you an unlocked PCM that contains a couple of generic tunes.
    You remove your factory PCM and store it. ((you will need this later)) Once installed, the new PCM will backup the factory settings before it flashes the generic tunes. Several days BEFORE you take your car in for any service you need to swap the factory PCM back and you need to drive it to allow the data collection. While I have not done this with my 2015, I have done similar with other vehicles and it was recommended that I drive approx. 100-miles before taking to the dealer so that sufficient history was stored.
    • Useful Useful x 2
    • Funny Funny x 1
  11. Cglhawk260
    Cglhawk260 Silver Member
    Jul 20, 2015
    357
    135
    CT
    How does the switching back -and- forth from one unlocked PCM to the factory locked PCM affect the odometter reading? If the accuracy of the odometer is no longer in sync can this affect the resale value of the car?
  12. Ray Hunsaker
    Jan 26, 2015
    624
    202
    bump
  13. moparbrad
    moparbrad Hellcat Member
    Jul 8, 2015
    62
    14
    Florida
    IT DOESN'T, THE MILEAGE IS STORED IN THE CLUSTER
    • Winner Winner x 2
    • Useful Useful x 2
  14. moparbrad
    Jul 8, 2015
    62
    14
    Florida
    sorry for the caps lock, flipping back in forth from screens
  15. superbeegugs
    superbeegugs Gold Member
    Oct 28, 2014
    264
    102
    Hicksville, New York
    I have the Diablo Trinity and used the 93 octane tune in my 2012 Superbee. I really didn't notice anydifference before and after. Before I traded it in, I simply replaced the tune with the factory tune.
    I'd really like to see un-biased times for a Hellcat before and after the tune. I really don't trust Diablo - poor customer service and I think the tune is a scam.
    Someone prove me wrong with hard numbers.
2015 hellcat pcm removel
can ford pcm adjust for octane change
diablo 93 tune 2015 srt 392
diablo trinity modify tune
diablosport 93 octane tune
diablosport trinity challenger
swapping octane tunes
trinity ecm 93 oct custom tuned
