Difference between the upper and lower pulley?
Discussion in 'SRT Hellcat Builds' started by Hemibuck, Jan 28, 2016.
  1. Hemibuck
    Hemibuck Gold Member
    Jan 9, 2015
    1,784
    422
    WA
    So this is my first blown car and I'm a little ignorant when it comes to the pulleys and how they change the power output. Can someone break down the difference between changing the upper and lower pulley. Also the location of the lower. I think I understand where the upper is located and it seems to be working great for most with a tune. I will be waiting to see the longevity of these recent upgrades before I decide to pull the trigger. hanks in advance for the advice!
  2. Lord Hellcat
    Jan 6, 2015
    1,609
    726
    UK
    The lower pulley is the crankshaft pulley
  3. Hemibuck
    Jan 9, 2015
    1,784
    422
    WA
    Got it. I'm not messing with that one. I might do the upper and a tune someday. Thanks.
  4. Lord Hellcat
    Jan 6, 2015
    1,609
    726
    UK
    I am doing the upper pulley 2.85 and installing the ATI superdamper standard size. Tuning by HHP. Looking forward to getting it all done by the end of next month
  5. Hemibuck
    Jan 9, 2015
    1,784
    422
    WA
    Can you exsplain the difference in the size of the upper? I have heard that one is more for a street set up and the other is for a race set up. Also is the ATI a new crank pulley?
  6. Hemibuck
    Jan 9, 2015
    1,784
    422
    WA
    The crank (lower pulley) is going to turn the motor over faster and the upper is turning the SC faster correct?
  7. Ray Hunsaker
    Jan 26, 2015
    588
    192
    is what they do is spin the blower faster upper is smaller lower is bigger. its easy the change the upper (once you have the metco) back to stock or race pulley or in my case ive have a 285 to make up for altitude.
  8. BeeHappy
    BeeHappy Senior Hellcat Member
    Aug 29, 2015
    129
    35
    GA
    Crank "drives" everything
    ratio changes
    stock gives you 11-12 psi
    1. smaller blower pulley with stock crank pulley gives you more psi...say 13psi
    2. larger crank pulley with stock blower pulley gives you ......say 15psi
    3. larger crank pulley with smaller blower pulley gives you ....say 17-18 psi
    *now psi is not real but you can see how it progresses.
    1. change the upper pulley get mild boost
    2. change lower pulley get med boost
    3. change both....get lots of boost
  9. Hemibuck
    Jan 9, 2015
    1,784
    422
    WA
    Got it thanks!
  10. Hemibuck
    Jan 9, 2015
    1,784
    422
    WA
    Ok got it. Looks like they are getting great gains with just the upper and a tune with stock intake and exhaust. That is amazing considering you don't need to drop coin for intakes and exhaust and can get almost 100 HP.
  11. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,199
    352
    It's all about the ratio of the damper diameter to the supercharger rotor pulley. Make the upper pulley smaller and the supercharger rotor spins faster for the same engine speed. Make the damper larger and the pulley ratio also increases so the supercharger rotor spins faster for the same engine speed.
    The ATI pulley alone results in about a 2.6 pulley ratio vs a 2.4 stock. If you leave the damper stock and run the 2.85 in upper pulley it is an even higher ratio, by memory closer to a 2.8. Change both pulleys and you get even higher pulley ratio.
    The Metco range is wide enough I don't see the need to change the damper anymore.
  12. Mr. Robert Lee Jones
    Mr. Robert Lee Jones Silver Member
    Jan 31, 2015
    137
    55
    178
    Scottsdale AZ
    I had a really bad experience with the last car I started fing around with. So I'm terrified of screwing up my HC. But would love to do the upper pulley and tune.
    What is the downside? Why would I not do this? Has anyone had a bad experience with upper pulley and tune?
  13. Hemibuck
    Jan 9, 2015
    1,784
    422
    WA
    I feel the same way. Why not? I am sure we run the risk of blowing gaskets with the extra boost but it's not a ton more. I feel that these cars were making close to 800 in the pre productions versions and they took it down to make it compliant with EPA standards. So I am sure we will have little to no problems with the upper and a tune but I am going to wait for a few more months before I decide to do it. Withing a year we will see what the weak points of the upper and a tune are. It's hard to not wan another 100 HP though....hehe!
  14. Draggin
    Draggin Rookie
    Oct 30, 2015
    28
    10
    If you want to start screwing with the pulleys put long tube headers with no cats. These cars build a lot of heat and I know of a couple cars that have lifted ringlands. Also if screwing with either pully you will want to pin the crank.
  15. Hemibuck
    Jan 9, 2015
    1,784
    422
    WA
    At the cost and PIA factor of installing long tubed and cat delete no thanks.
ctvs upper pulley vs lower pully
difference between fast and loss pulley in point
difference between supercharger pulley and damper pulley
hellcat pulley swap
lower pulley challenger srt 392
upper pulley and lower pulley replacement for hellcat
what is lower pulley
why change upper and lower pulley for supercharged engines
