Differential Not Centered
Discussion in 'SRT Hellcat General Discussions' started by PlumHell, Jan 20, 2016.
  1. PlumHell
    PlumHell Hellcat Member
    Nov 7, 2015
    37
    14
    South Texas
    Has anyone noticed that their differential is not centered?
    I recently had some 305/35/20 NT555R's installed and noticed the driver side tire sticks out past the wheel opening about 1 1/2 inches and the other side is even with the wheel opening.
    Can this be corrected and how?
  2. Rocket Man
    Rocket Man Silver Member
    Aug 27, 2015
    201
    87
    178
    Lexington Park, Maryland
    Was this after the car was back on the ground and had been driven?
  3. PlumHell
    Nov 7, 2015
    37
    14
    South Texas
    I noticed it as soon as it was back on the ground.
  4. BlackbirdWS6
    BlackbirdWS6 Gold Member
    Jan 28, 2015
    369
    145
    Drive it and recheck. The wheels get tucked up and won't slide back outward persay until you drive it and everything fully settles.
  5. PlumHell
    Nov 7, 2015
    37
    14
    South Texas
    Thought that myself. Drove it, did a couple of launches but no difference. Gonna put it on the lift this week end to check it out. Just wanted to see if this has been reported before.
  6. Jim M
    Jim M SRT Hellcat Supporter Gold Supporting Member
    Jan 12, 2015
    615
    Oviedo, FL
    1 1/2" is WAY more than you would get with a little axle slide from jacking up. And the differential location would have nothing to do with it unless something was damaged at the tire shop. Are you using the stock wheels or aftermarket? It sounds more like different wheel offsets. Also check to make sure the hub of the wheel that is protruding is up flush with the brake hub.
  7. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,032
    I agree, that's a lot of difference, sounds like your car is dog leggings, my brothers new serria did the same thing...if it is doing, it seems like it would stress the drive line over time...sounds like needs to be put on the lasers
  8. YLWJKT
    YLWJKT Silver Member
    Oct 12, 2015
    411
    The diff is bolted to the frame in a cradle.
    It would be really difficult to get it off center wothput breaking something.
    Did you go with new wheels?
    It's possible the wheels are mismatched and you have the wrong offset on the side that's sticking out.
    Is there any noise? It could be that the wheel was not installed properly on the hub, or that the axle somehow got pulled out of the housing.
    I'd take it back to the tire place asap.
  9. PlumHell
    Nov 7, 2015
    37
    14
    South Texas
    I'm using stock wheels and the wheel is flush up against the hub. I've already taken it back to the dealership for alignment because it drifts to the right and they said the alignment was good. I don't think they checked the rear at all.
    Plan on putting it on the lift this weekend to check and make sure all is secure.
    Thanks.
  10. YLWJKT
    Oct 12, 2015
    411
    Have any pictures?
  11. Colorado Hellcat
    Colorado Hellcat Silver Member
    Nov 13, 2014
    548
    121
    This should be obvious but are you sure both tires are 305/35/20 ? Could one of them be a 315?
  12. Jim M
    Jan 12, 2015
    615
    Oviedo, FL
    I think the short answer here is that, unless somebody at the factory REALLY screwed up, the issue is not with the differential location.
  13. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,659
    481
    368
    Henderson, NV
    If there are no functional issues, I'd leave it alone. But that's just me
  14. hellcat1
    Sep 27, 2014
    10,672
    2,032
    I would take it to a good alignment shop, just to have it checked out...gmc service checks it every time I took my truck in..either way, it doesn't sound correct
  15. Jim M
    Jan 12, 2015
    615
    Oviedo, FL
    If you don't get it resolved you are going to end up with bent sheet metal or a cut tire or both.
hellcat differential breaking
