Directional or not?
Discussion in 'SRT Hellcat Wheels and Tires' started by rrroscoe, Apr 11, 2016.
  1. rrroscoe
    rrroscoe Gold Member
    Jul 20, 2015
    151
    126
    493
    Kentwood, MI
    Are the P zero summer tires directional? When I took them off to put on the winters, I marked which ones were on the back and the front, but not which side. I figured they were directional with the markings on the sidewall, but I don't see the designation. Am I missing something?
  2. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    I cant remember if they are or not. Look on the side wall. It will tell you if the have to roll one way. It will also tell you which side faces out.
  3. rrroscoe
    Jul 20, 2015
    151
    126
    493
    Kentwood, MI
    I see the "outside" marking, but nothing for direction.
  4. Tire God
    Tire God Hellcat Member
    Apr 5, 2016
    33
    18
    No. They are asymmetrical (not symmetric). There is an outside and inside marking. But it doesn't matter where you put them because no matter what the outside will be outside.
  5. rrroscoe
    Jul 20, 2015
    151
    126
    493
    Kentwood, MI
    Thanks
  6. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,598
    655
    This is deep. Haha.
    Sounds silly, but it is what it is.
  7. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    Since there is no "direction" arrow or other indication of direction it is not directional as Tire God said..
  8. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,459
    768
    Directional couldn't happen if they are rotatable.
  9. Tire God
    Apr 5, 2016
    33
    18
    Directional tires are rotatable. Just can't cross them(unless you flip them on the rims). They have to stay on the same side of the car. The only exception is the few tires like the Goodyear Eagle F1 G2 for the Camaro ZL1, Corvette Grand sport, they are staggered fitment, asymmetrical, and directional. Meaning there are 4 part numbers each labeled rf,rr,lr,lf. There might be one other tire like that but I can't remember.
  10. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,459
    768
    The rotation pattern for the Hellcat does not lend to directional tires.
  11. Tire God
    Apr 5, 2016
    33
    18
    Yes the preferred rotation pattern is to cross the tires so that every tire visits each position eventually. And that is for all cars(except special fitments). But if you have directional tires you can still move front to back just can't cross them. But most tire manufacturers have done away with directional tires anyway, it's actually an old design and is not near as good performance wise in the wet or dry as current asymmetrical tires. Plus directional tires tend to wear uneven due to the tread pattern, lack of being able to cross them (unless you flip them on the rims), and performance alignment settings. They get choppy, cupping wear. It's best to run a summer tire like the Pirelli PZero. The only current tires that need that design are the drag radials because they have to have a small amount of water evacuation capabilities to be street legal. Like the Nitto NT555R, NT05R, MT ET street SS, ect. But these tires wear out completely, and quickly so you don't have to worry about tread design or rotation patterns haha.
pirelli p zero directional
