DIY: Charger Hellcat Shark Fin Antenna Removal
Discussion in 'SRT Hellcat Appearance' started by JonWrong, May 26, 2015.
  1. JonWrong
    JonWrong Silver Member
    Feb 3, 2015
    360
    52
    Orlando, FL
    So... I originally ordered a car with a black roof, but my order never got built. I bought a white charger (no black roof) and wanted to wrap it black. But I was not about to let some wrap tech try to figure out how to remove the antenna. Another forum member sent me the official Dodge "how to," and it said to remove the entire headliner. (Thanks, fnkychkn!)
    With some patience and luck, I figured it out (and it is pretty simple).
    1. Remove the passenger side rear door seal from the top of the door (door is open obviously). Just pull lightly.
    [​IMG]
    2. Remove the handle/light above the door using a plastic trim remover to find the torx fasteners.
    [​IMG]
    3. Use a T30 bit (have your girlfriend hold it for the pic), and remove these bolts.
    Pic missing.
    4. Let the handle assembly hang.
    [​IMG]
    5. Remove the c-pillar cover from the top sides. Work your finger under gently and find the top friction clips and pull one loose on each side near the top. The clips have a band to keep it on when the airbag deploys. Make sure you are near the clip when pulling or it could bend/crease the c-pillar cover.
    Pics missing.
    6. Then, unclip three friction clips on the headliner in the center (near the third brake light). They look like this (green in pic).
    [​IMG]
    7. On each side of the three green clips, are another clip you will need to pull down to get the room to work.
    [​IMG]
    8. Now, you can see the shark fin wire harness and single screw (10mm), which is just beyond the black plastic look grill in the pic below. It was too tight to get a clear pic.
    [​IMG]
    9. This is the bolt and fin removed.
    [​IMG]
    10. Last, when you remove the fin (you will need two people). Someone has to pull from the top (light pressure) while the other pushed in some plastic spring clips on a plastic retainer (the wires run through it) in order to pull antenna free. It is in the pic above just below the bottom of the fin. It fit through the hole perfectly, so you must line it up.
    11. Re-installation is the reverse. I will post pics of the wrapped roof by the end of the week.
    Thanks, enjoy, and good luck.
    • Useful Useful x 5
  2. AvsBest
    AvsBest Silver Member
    Nov 23, 2014
    1,056
    168
    198
    British Columbia, Canada
    Did you happen to take a pic of the part number or know it?
  3. B5 Blue
    1,748
    Very nice JW
  4. JonWrong
    Feb 3, 2015
    360
    52
    Orlando, FL
    I will look tonight. I will also post some pics of the car with the wrap. It looks awesome!
  5. JonWrong
    Feb 3, 2015
    360
    52
    Orlando, FL
    I was able to blow up one off angle photo and get it. The following numbers are on the label from the top (and left to right down):
    P88239818AA 801180 0075
    40908H
    81038-A
    150234400100 (this one may not be 100% right)
  6. Levy4u
    Levy4u Rookie
    Dec 7, 2015
    4
    0
    1
    Hey JonWrong, is there any chance you can reupload these photos so they show?? Thanks!
  7. JonWrong
    Feb 3, 2015
    360
    52
    Orlando, FL
    Yes, let me work on that.
  8. Hb hellcat
    Hb hellcat Black Betty...BamAlam!!!
    Feb 14, 2015
    619
    204
    Sunny Southern California
    I posted pix of the numbers on the box for my charger pitch black shark antenna in an earlier post, if you need, I can shoot a new pic of the box and repost with numbers.
  9. JonWrong
    Feb 3, 2015
    360
    52
    Orlando, FL
    I fixed what I could. I hope this helps! I don't how they lost my other pics; I will have to try to find them on my PC if you need them.
  10. Markp
    Markp Gold Member Hellcat Car Club Gold Supporting Member HCC Club Member
    Aug 5, 2015
    2,484
    1,182
    668
    Ontario, Canada
    pics??
  11. JonWrong
    Feb 3, 2015
    360
    52
    Orlando, FL
    Do they not show up in the original post now? I see them!
  12. Markp
    Aug 5, 2015
    2,484
    1,182
    668
    Ontario, Canada
    Not on my computer ??
  13. Levy4u
    Levy4u Rookie
    Dec 7, 2015
    4
    0
    1
    I see them now, besides the "pics removed" ones. Thanks!
  14. PhantomWorks
    PhantomWorks Silver Member
    Feb 10, 2015
    553
    187
    Florida
    I can see that there are supposed to be pics, but there are none? Dying to see it!
2015 charger rt antenna remove
charger hellcat antenna removal
dodge challenger 40908h
how to remove antenna charger srt
how to remove roof antena on charger rt
how to take antenna off 2015 dodge charger
