Do I have a coolant problem
Discussion in 'SRT Hellcat Maintenance' started by AER, Aug 7, 2015.
  1. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    Got the car back from the dealer today and he replaced the top hose and the clamps per the tsb. Was doing 30mph town driving 83 degrees outside. The temp of the car is 219-221 and I can smell coolant. Looked under the hood and the top hose is NOT leaking.
    So..... Coolant smell could simply be from when he swapped the hoses, but I am worried about the temp.
    Doesn't 219-221 in 83 degrees at 30 after 10 minutes seem rather high?
  2. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    If the car not tuned drive it like you stole it anything happens use your warranty and free towing ;) plus a rental while car getting repaired nothing to be lost .....:don't be concerned if no smoke or puddles on floor
  3. TallCool1
    2,432
    814
    Pacific NW
    Not necessarily no.
  4. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    Dude I live in NYC and I can honestly say I have no idea what you just said
  5. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    What is a temp number that should make me go, hmmmm..... this is a problem?
  6. ChallCat
    ChallCat Gold Member
    Nov 15, 2014
    423
    250
    Kansas City
    That range is normal, but the fan should be running on high at 219-221 and the temp should drop back to the low 200's pretty quick. Just make sure the fan is working. The fan is pretty loud, you can't miss it and again, the temp falls pretty fast once it kicks on.
  7. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    Very stupid question, you are talking about the radiator fan correct? If so, that is fine. Is there a secondary cooling fan you are mentioning? I know for instance on my race cars we do run multiple fans in places.
  8. Next Phase
    Next Phase Silver Member
    Oct 22, 2014
    908
    301
    173
    In traffic, my HC gets up to 219-222 degrees routinely until the fans kick on. That is normal. Once the car is going at freeway speed (70-100 mph) it is at approx 200 to 204 degrees.
    I would start to get alarmed at 240 + degrees...anything higher and I would be looking for a place to pull over and shut it down.
    I would let the dealer know that you smell coolant and get their input. Some have reported the smell with the heat turned on. I don't feel that is acceptable for me as it's my daily driver and I would need to find the root cause.
  9. ChallCat
    Nov 15, 2014
    423
    250
    Kansas City
    The fan I am talking about is multi-speed and ramps up in several stages once temp hit 219 or so - mine sounds like a jet at full speed... I'm not sure if it runs all the time or not, but once it hit's high mode the temps come back down pretty quick - within 20 seconds or so...
  10. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    I suspect the coolant smell is simply from having the top hose changed or refilling the coolant tank. I have done enough of those to know you always spill a little and it just cooks off. I will take it out this morning and run it for 20 minutes to see
  11. ChallCat
    Nov 15, 2014
    423
    250
    Kansas City
    9k miles and mine's never gone over 223 degrees... I'd start to worry if the fan was not coming on full blast at 219 or so and definitely if the temps got over 225 for more than a few seconds...
  12. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    Really wound it out for 20 minutes just now (temp 68 degrees) never got above 201. Suspect it was just a warm day and nothing to worry about
