Does anyone know how to get to cig lighter in the Charger?
Discussion in 'Dodge Charger SRT Hellcat' started by JonWrong, Jun 24, 2015.
  1. JonWrong
    JonWrong Silver Member
    Feb 3, 2015
    358
    51
    Orlando, FL
    I want to tap the 12v key on power on the cig lighter in my charger hellcat for a radar detector. Does anyone know how to get at it? I did not want to start trying to pry things apart without asking for a little help.
    Thanks!
  2. JonWrong
    Feb 3, 2015
    358
    51
    Orlando, FL
    Ok, well I can't wait forever with no radar detector. I initially installed my radar detector with the cable running down the driver's side A pillar. I used the OBDII port to power it b/c it used data from the car to auto mute below a certain speed. Apparently, OBDII devices are known to wake up the ECU on LX chassis cars and kill the battery. And that is what happened to me.
    So, I know there is keyed 12v and ground going to the rearview, but there is a thread on this. It's almost impossible to remove that trim without marring/scratching it. I found the connect harness in the A pillar that goes to the mirror and tested each wire. Pink (pin 1) is 12v with key on, and black is ground (all the time). Since the detector used a 2 amp fuse, I spliced in there and soldered the joints. If I ever need to run more 12v keys sources, I will use that as a signal wire to trip a relay.
    Pics below. Cig light info may still be helpful in the future.
    [​IMG]
    [​IMG]
  3. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,117
    3,011
    863
    Thanks for the post. I will be installing mine in the same spot.
