Puddle light Install instructions
Before you start if you don't want the Hellcat only facing one way and not inwards on each door you will have to take one of the projectors apart and flip the image around.
This is how to change the image in the projector.
Puddle light install, Enjoy.
I re-posted it in a new thread so as to not get confused with ordering them!
1. roll down the window
2. remove the three Phillips screws at the bottom of the door.
3. remove the plastic cover behind the door handle and remove the Phillips screw.
4. Remove the plastic insert on top of the arm reset area and then remove the Phillips screw
5. Closest to the door hinge is a push pin, push in lightly and it will be come loose to remove.
6. Starting from the bottom get a grip and pull firmly on the door panel, it will start to pop loose. YOU NEED TO USE SOME FORCE
7. Disconnect the three electrical connectors
8. Un-bolt the door handle using an 8mm socket and slip the handle out of the door.
9. The panel is now free. For my ride I measured 12-7/8 from the edge of the existing light to center of where I drilled as the panel has a nice void to fit the light. I then measure out 1-1/8 and drilled the hole.
10. Unscrew the nut and slide the wiring and light into the hole. Install the lock nut and tighten but not too much and then lock off with the set screw.
11. Now I used as self adhesive zap strap mount and stuck it to the inside of the door panel. I then coiled up the excess wire and zap strapped it in place.
12. Now cut the orange/purple stripe wire as your positive and either solder or crimp the positive from the puddle light.
13. Now do the same for the ground with the yellow/white stripe.
14. I checked the voltage and I didn't like the drain with both lights going so I removed the OEM bulb, Your choice, also less heat that factory bulb was hot.
15. Now put it back together.
16. Open the door and adjust the position of the puddle light and enjoy!
Drivers Side
Passenger side
Enjoy!
- unscrew the rear of the puddle light to remove the led.
- using something that will not mar the lens, push from the front of the lens to remove the prism cylinder from the rear as it is just a friction fit.
- once out the plastic cylinder will separate by gently prying them apart begin careful to not have all the prisms fly apart.
- There are six prisms inside with the image in the middle, inside a plastic frame.
- there is a little tab on one end that you can separate the image and flip around.
- Re-assemble in reverse being careful to install the small o ring before the outer lens and be mindful of finger prints or debris.
Drivers Side
Passenger side
Enjoy!
