Drag racing and auto trans care
Discussion in 'SRT Hellcat Performance' started by Top Cat, Apr 14, 2015.
  1. Top Cat
    Nov 26, 2014
    1,925
    1,087
    768
    Doylestown,Pa
    The trans is often forgot about when it come to maintenance when you drag race your car, so the question is :
    When should you change the fluid?
    Since we will be racing the Charger fairly often I will be changing the fluid about every 25-30 pass's, I know that sounds excessive but in the past running the NAG1 it was very important for the health of the trans...this past weekend where we hot lapped 14 pass's that was brutal on a trans as it didn't have time to cool down much, so I will most likely change it after Saturday's runs...
  2. B5 Blue
    1,747
    When you do are you getting the ZF fluid? How are you doing this flush with machine or using cooler line engine running or dropping the pan?
  3. Top Cat
    Nov 26, 2014
    1,925
    1,087
    768
    Doylestown,Pa
    First change the dealer will be doing, once I know a little more about the A8 I will be doing it myself.
  4. B5 Blue
    1,747
    ZF trannies are filled and then checked at no more than 35c by removing the trans pan drain which is like a cup that drops down and is full when oil starts coming out. Need a hoist for this so not customer friendly and I hope the tech knows this procedure. Does a HC have a dipstick tube? Audi's don't so it's filled with garden sprayer type pump.
  5. SRT_HC_707
    Jan 1, 2015
    4,971
    1,449
    70.196059, -148.559760
    Disclaimer.... I'm not a tech but I do play one in my garage... Heat kills transmissions and racing generates lots of heat... I think auto trannies are one of these most neglected items maintenance-wise in general (even for daily drivers). For me it will get changed every 25K. If racing I would do it more often but how often I guess depends on how hard you are hammering it.
    The procedure is very familiar to many late model ZF's on the market. The Mopar fluid is about $12 per quart online. Not sure how many you need but I thought I read (going from memory) that trans capacity is 9 quarts so it's going to be less than that since you never get it all out.
    The procedure to change the filter and to check the oil is in the WIKI http://www.hellcat.org/wiki/?title=Transmission
    The part number for the fluid is in the MISC section of the WIKI (there is a table with part numbers).
    I'm pretty sure the fluid is ZF LIfeguard 8 but you aren't going to get Lifeguard 8 for less than $12 anyway so might as well go with the Mopar fluid and be 100% sure you have the correct stuff.
    There really is no magic to changing the fluid here. Just need to follow the procedure. One ghetto trick I always use when servicing transmissions.... I check the fluid first following the procedure. Then when I drain the trans I capture the fluid in a container. Finally I have two 2 1/2 gallon plastic jugs. One is only used for dirty trans fluid and the other is for clean. I put the dirty in the dirty bottle. I then add clean fluid to the clean bottle and pump it in from there. This way I'm very sure that what I took out is what I'm putting back in. I alway overfill the clean bottle just a hair since you never get 100% of the old into the bottle and you never get 100% new out of the bottle... Gets me very much in the ballpark though.
  6. B5 Blue
    1,747
    Thanks for the Wiki and like I said not fun when you're used to a hoist
  7. DB2
    DB2 Silver Member
    Feb 4, 2015
    346
    85
    Lifegaurd 8 is the fluid.
    Not sure on the price vs Mopar.
2015 challenger zf auto trans fluid
zf allpar drag racing trans
