Drag Wheels
Discussion in 'SRT Hellcat Wheels and Tires' started by Fryguy302, Mar 17, 2015.
  1. Fryguy302
    Fryguy302 Rookie
    Oct 23, 2014
    27
    7
    Oxford, Michigan
    I just ordered some race stars for my Hellcat, anyone else using these? I ordered 17s all around, and the new style M/T Drag Radial II.
  2. B5 Blue
    1,745
    Are you sure 17's fit the rear cuz they won't on the front
  3. Fryguy302
    Fryguy302 Rookie
    Oct 23, 2014
    27
    7
    Oxford, Michigan
    Not sure they fit the rear, but we'll find out. I have read of others using 17s in the rear.
    The front I was hoping would fit with a spacer.
  4. B5 Blue
    1,745
    Spacers aren't the issue up front the wheel needs to go over the brake caliper and 18's don't so 17's aren't either. I think the same in the rear w/17's
  5. HellDoc
    HellDoc The Doctor is IN!
    Jan 8, 2015
    249
    154
    Atlanta, GA
    Rears (most models) should fit on 17" as they are just SRT rears, same as previous years, and many out there running drags. Fronts not going to happen. In fact, I'd be surprised if even a 19" would fit. Front caliper just that big. So as long as outer diameter meets or slightly exceeds the front once you have your drag tire mounted on your 17 thats fine. I was looking at the M&T 275/50r17 (275 50R17 28 Tall )
  6. B5 Blue
    1,745
    But there can be shock interference in the rear as it's canted toward the caliper
  7. HellDoc
    Jan 8, 2015
    249
    154
    Atlanta, GA
    You betcha! offset and wheel shape will be a key consideration!
    Weld racing has purpose built wheels for late model challenger : Weld Racing 17x10 LC/LX SRT Black Center - 71HB7100W67A.
    I would LOVE to try them out for fitment.
  8. B5 Blue
    1,745
    Let me know if you do, I'm looking at the 20" stuff as we speak
  9. Fryguy302
    Fryguy302 Rookie
    Oct 23, 2014
    27
    7
    Oxford, Michigan
    Yep, my brain fade. Just cancelled the order on the fronts at Summit.
    Still excited to see how the rears work, P305/45R17 ET STREET R tires.
  10. Hellcat Jack
    Hellcat Jack Silver Member
    Feb 12, 2015
    150
    67
    178
    Weld 17x 10 will fit the rear no problem. The Hellcat rear is the same as past SRT's starting in 08. Its what I'm putting on mine for the track with a 28" tall tire. Either M&H or MT Drag radials.
    My experience with Race star was not good at all on my 08 SRT. UNLESS....they have changed something they are a uni-fit set-up with washers that sit below the lug nut. They will bend the first time you put them on and then they are a REAL PIA to get off.
  11. Fryguy302
    Fryguy302 Rookie
    Oct 23, 2014
    27
    7
    Oxford, Michigan
    Yes, I have run them before, they're definitely not the best quality wheel. I don't intend to run my Challenger a lot, I have other cars that I use at the track much more often. I just bought the race stars because I didn't want to spend too much on wheels that I will only use a couple times. My goal is a 10.8x on drag radials, stock. Once it runs that number, I won't need to take it to the track again.
  12. TheWhiteOne
    TheWhiteOne Rookie
    Feb 14, 2015
    27
    12
    Keep us posted on fitment.
    KW
  13. B5 Blue
    1,745
    I can't find a 17 or 18 inch Weld wheel unless you want 25 or 32mm offset which is way too much. When you got to 10" offset needs to come down
  14. Hellcat Jack
    Feb 12, 2015
    150
    67
    178
    Sorry..... I thought the rims Fireball put on in Bradenton were Weld. But They are Bogarts. He's going to measure the width tonight but believes they are 10". I also talked to Josh at HHP and they have sold 17x10 Welds to one Hellcat owner a couple months ago but hasn't heard anything. He assumes they fit . I'll find a set and test fit them from someone local that owns a set.
  15. chuck spoto
    chuck spoto Gold Member
    Feb 8, 2015
    182
    108
    Crystal Lake / Johnsburg, IL
    Has anyone tried those 17' wheels yet? HHP and Rich Bogart claim they will fit but cant confirm as of today.
2016 dodge charger drag wheel setup
charger hellcat 18 inch wheels
drag wheels for hellcat
drag wheels for the hellcat
hellcat bogart wheels
hellcat drag wheels
hellcat weld wheels
racing wheels for hellcat
