Driveshaft Loop Required w/Slicks NHRA Rules
Discussion in 'SRT Hellcat General Discussions' started by B5 Blue, Feb 6, 2015.
  1. B5 Blue
    1,746
    Investigating this reveals that unless there is a crossmember to catch the front of the driveshaft (which I don't have a car to check and in the past always holds the rear trans mount on old B and E cars leaving the shaft open i.e needs loop) NHRA rules shows it requires a driveshaft loop section 2:4. This means drilling the floor pan and I won't do that to mine. In summary slicks=loop. Street tires running quicker than 11.49 1.4 mile or 7.35 1/8 mile=loop.
    Any NHRA inspectors in here?
  2. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,018
    491
    403
    Westchester
    1) i thought this only applied to modified cars, not stock ones. Cause rollcages are going to be needed also then right?
    welp good thing drag racing is all about consistent times now, not whos faster. Just nail your times with street tires and you'll be good.
  3. Next Phase
    Next Phase Silver Member
    Oct 22, 2014
    919
    306
    173
    Safety first... This isn't going to be a collector car, if you are going to be drag racing heavily, nothing wrong with adding the loop. Just my 2 cents.
    The track I go to is really lax with rules...most of my time is during private track days.
  4. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,709
    2,039
    I believe our cars already have this loop
    • Funny Funny x 1
  5. Next Phase
    Oct 22, 2014
    919
    306
    173
    I'm wondering if having a trans tunnel cover (like in the Vipers) will suffice for this requirement. I've never seen a track Inspect a car that heavily
  6. B5 Blue
    1,746
    It's not just for the tunnel which is why they state OPEN shaft and I disagree on the collector car thing. All the Prius, Ann Arbor and Cali tree huggers along with MAHC will see to it.
  7. Furyous64
    Furyous64 Senior Hellcat Member
    Feb 5, 2015
    90
    35
    If the car is not modified you can run much faster than 11.49 before they require additional safety equipment. I would think the Hellcat has everything it needs to run safely otherwise the NHRA would not have certified the times on DR's at 10.8. As soon as you modify the car, that is if the inspector can tell, he may not let you run at all if he wants to be a stickler.
  8. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,658
    543
    423
    Chattanooga, Tennessee
    That is called a carrier bearing and is standard on any two piece driveshaft. A loop would be used so that the half of the driveshaft that twisted apart would not drop down to the pavement and catapult the car sending it out of control. In my opinion, if you are going to run drag radials on the Hellcat, it would be wise to install a driveshaft safety loop. An ounce of prevention..............
  9. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    So a 2-piece drive shaft would require two loops...to really contain it from beating the snot out of your floor pan or pole vaulting the car.
  10. mopar sickness
    mopar sickness Silver Member
    Oct 2, 2014
    309
    104
    Read the section on production vehicles in the nhra rules.as long is there no structural modes your good
  11. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    One of the reasons we use carbon fiber shafts in all our race cars, if they let go all they do is disintegrate into small pieces. We have seen local tracks getting a bit more strict last year in the Mid Atlantic region, 11.49 was a magic number which a lot wanted roll bars, we even had state troopers in tech watching at some tracks in New Jersey.
  12. Furyous64
    Feb 5, 2015
    90
    35
    That's crazy considering it seems like the NHRA is getting a bit more lenient lately. You use to not be able to change anything on the car or it would be considered modified and you could no longer skate by the roll bar nazis. Everything had to be OEM or appear to be OEM. Now it seems a few guidelines have changed and as long as whatever you put on the car is put in the stock location it's ok. NHRA production car guidelines does not require a roll bar unless faster than 135mph I believe. Roll cage required faster than 9.99 E.T. Then again whoever is running tech can decide whatever he wants I suppose.
  13. B5 Blue
    1,746
    Can't find it yet
  14. Furyous64
    Feb 5, 2015
    90
    35
    I believe its Section 10 of the 2015 NHRA rule book. "Factory Stock" is the category
drive shaft loop placement
drive shaft loop rules
driveshaft loop
driveshaft loop rules
nhra driveshaft loop
nhra driveshaft loop location
nhra driveshaft loop rule
nhra driveshaft loop rules
