Driveshaft loop
Discussion in 'Dodge Challenger SRT Hellcat' started by Jungle Jim, Jan 29, 2015.
  1. Jungle Jim
    Jungle Jim Gold Member Hellcat Car Club HCC Charter Member
    Sep 27, 2014
    454
    298
    513
    Kentucky
    Has anyone checked/tested any of the available ds loops, such as the one from Speedlogix?? I have one that was to be installed on my '12 SRT8 Challenger and never got around to it.
  2. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,770
    Wisconsin, USA
    I thought there was a thread on them. or a thread about how most cars did not need them, was a while ago.
  3. Jungle Jim
    Sep 27, 2014
    454
    298
    513
    Kentucky
    If there was I missed it. Will look for it. Thanks 70Cuda. Just as info I had a B5 70 Cuda 383 in the past.
  4. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,614
    508
    423
    Chattanooga, Tennessee
    I would like to know where the driveshafts are twisting in two. Will be important in locating the safety loop as well as the design of such.
  5. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    Looks like a 2-pc driveshaft from the factory. Dump that POS and get a thick wall aluminum shaft or a carbon fiber driveshaft. Eliminate the first weak spot.
  6. Paladin06
    Sep 3, 2014
    4,701
    1,853
    San Tan Valley, AZ
    I likie this idea. Who makes one?
  7. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    Driveshaft specialties can build you one if you take the measurements. I think they have a page on their website that tell you the points that they need measured. You'll need a decent set of calipers to measure the u-joint holes and other diameters, although I'm sure you could probably go larger in diameter for the tube...but I haven't been under a HC yet, so I'm just guessing. Most major cities have drivetrain places that can build them, they aren't too expensive. Sometimes you get lucky and it happens to be the same length as some other vehicle made in the past and there are heavy duty versions you can buy used, like something made for a truck.
    Also, if the factory driveshaft is 2-pc, there may be a good reason for that (some angle that had to be solved), so that has to be taken into account as well.
  8. rayzazoo
    Nov 8, 2014
    3,494
    1,294
    668
    Same car, two separate instances.
    [​IMG]
    [​IMG]
    [​IMG]
  9. B5 Blue
    1,745
    I looked at DSS on Thursday and read how to measure. First point is wheels on the ground so you will need a pit or a drive on lift such as an alignment rack. I don't know who could crawl under the car in your driveway unless it was a tot. I didn't call them yet because there's not enough Chargers out there yet to see if they already knew the dimensions but I can Monday.
  10. CatBurghlr
    CatBurghlr Gold Member
    Jan 6, 2015
    253
    Pittsburgh, PA
    Pics from Rayzoo are scary looking.
  11. rw99
    rw99 Silver Member
    Feb 13, 2015
    192
    80
    178
    Castro Valley, CA
    Any further info on available DS loops for Hellcats? Or, alternatively, proven aftermarket drive shafts?
    Thanks,
    Rich
  12. VanishingPoint
    VanishingPoint Silver Member
    Jan 6, 2015
    923
    235
    Somewhere, Texas
    Cheap chi-com pot metal :mad: and isn't there already a "driveshaft loop" on the factory one?
  13. bolivarshagnasty
    Oct 24, 2014
    1,614
    508
    423
    Not a loop, the carrier bearing halfway supports the two piece. With Johnny Hellcats, DS, looks like the heat shields and exhaust system held the shaft from dropping to the pavement. (see "Hellcat on a Tow Truck")
  14. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    Dr buick vendor for your driveshaft needs aluminum or carbon fiber and think he gives some money off list for forum
    Members and he has all the mesurements no need to do anything but send money PayPal and car info rest will be handled
2015 challenger drive shaft loop
2026 challenger hellcat driveshaft loop
challenger driveshaft loop
drive shaft loop 2012 dodge challenger srt 8
drive shaft loop for 2012 dodge challenger srt
driveshaft loop 2016 challenger
driveshaftloophellcatcharger
hellcat driveshaft
