DSS Drive shaft and Nitto 305/35/20 DR install
Discussion in 'SRT Hellcat Wheels and Tires' started by hellcat444, Jan 10, 2016.
  1. hellcat444
    hellcat444 Rookie
    Mar 22, 2015
    20
    2
    i am going to get my DSS Drive shaft and Nitto 305/35/20 DR install on the rear this weekend.
    Do i need to do wheel alignment as well?
    does the DR change the right height of the car to a point that wheel alignment is needed?
    Thanks guys!!
  2. FireLane
    Jul 23, 2015
    386
    105
    Palm Beach County, FL
    No, changing the rear tires will not affect the alignment, no worries, just go out and have fun!!
  3. BLK_MAGIC
    BLK_MAGIC Silver Member
    Dec 11, 2015
    407
    159
    Good upgrades should feel the difference, no alignment is needed.
  4. Hemi Rocket
    Hemi Rocket Gold Member
    Sep 27, 2015
    1,486
    Albany NY
    Yup... Bolt em on and go... no affect on alignment... just double check clearances as there can be subtle differences between cars. I haven't heard of anyone having issues with the 305's on stock wheels... DS can get close to the exhaust. ;)
  5. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,101
    732
    nothing to align
  6. YLWJKT
    YLWJKT Silver Member
    Oct 12, 2015
    405
    136
    If you're doing it yourself you don't need to remove the exhaust. Just loosen the front clamps and unbolt the rear and mid hangers and unplug the exhaust servos.
    The front bolts can be a ***** to get out because of all of the loc tite and limited space to work in.
    You will need a very short allen socket to tighten the new front bolts with a torque wrench. I cut an 8mm x 3/8 drive socket down to make a stubby that would fit.
    I also cut a 10mm one down for the large flange bolts in the rear.
    Don't forget to put sealant on the front flange.
    Also don't forget to put it into neutral before you lift the car.
    Taking my time it took about 3 hours, and that included painting my rear rotor hats black.
    [​IMG]
