Eibach Pro Kit Installed
Discussion in 'SRT Hellcat General Discussions' started by All2Easy, Jun 13, 2016.
  1. All2Easy
    All2Easy Senior Hellcat Member
    Apr 20, 2016
    53
    33
    Very happy with the outcome. Plan to have alignment done in about a week after the springs have settled. I know nothing can be done about camber or caster without more parts, but want to make sure toe is good to start with, and take it from there based on camber/caster readings. Car feels more planted, and ride seems unchanged.[​IMG]
    • Like Like x 5
  2. Mo-par!
    Mo-par! Bone Stock Hellcat Car Club
    Feb 21, 2016
    1,113
    550
    413
    Lebanon Valley PA
    When mine was aligned they could get all into spec but camber....let me know if you have the same results....make sure you give the shop the Eibach alignment specs.
  3. Mo-par!
    Feb 21, 2016
    1,113
    550
    413
    Lebanon Valley PA
    BTW, those TX black plates are sick...your lucky you can get em.
  4. Mods
    Mods SRT Hellcat Supporter Gold Supporting Member
    Feb 22, 2016
    17
    6
    Ottawa, Canada
    Looks great! Really digging that plate as well.
  5. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,199
    353
    Mine sits about like yours and all 4 tires are at - 1.8 deg. camber which works great as a track/street compromise. The toe had to be adjusted.
  6. kenhebe
    kenhebe Silver Member
    Jun 24, 2015
    519
    120
    Camber adjustment bolts will fix that.
  7. DGatzby
    Jan 16, 2015
    3,412
    1,792
    598
    Twin Cities, MN
    Help me, we can't find the "camber adjustment bolts".
    Front upper arm is not adjustable, neither are either the front or back rear top connecting arms. What are you using?
  8. All2Easy
    Apr 20, 2016
    53
    33
    Had my alignment shop look at the car yesterday. In my opinion, this shop is the best in Houston as they have a lot of experience with track car setups, lowered cars as well as lifted trucks. Have taken all my cars to them in the past.
    Front left camber: -1.8
    Front right camber: -1.7
    Back left camber. -1.4
    Back right camber: -1.4
    He did need to adjust the front toe in...front left was a bit too far out.. He was happy with the outcome, and suggested no adjustable control arms for the front or bushings for the rear. The car tracks straight, and the handling is in the sporty zone that I like. Overall, I am very pleased.
  9. USAFPILOT
    USAFPILOT Senior Hellcat Member
    Apr 6, 2016
    261
    64
    What Houston shop are you using, pm me if you want.
  10. Mo-par!
    Feb 21, 2016
    1,113
    550
    413
    Lebanon Valley PA
    Yep...getting the toe in right is huge for straight tracking.
  11. TrackDay
    Mar 28, 2015
    1,199
    353
    Sounds basically like my outcome as well. No need to adjust the camber.
  12. IndyHellcat
    IndyHellcat Silver Member
    Dec 4, 2014
    201
    62
    Central Indiana
    Got the Eibach springs put in yesterday and love the look. Ride remains the same except for when you roll over some bumps but nothing alarming by any means. Specs came out fine according to the installer per the Eibach specs. I don't have those numbers tho, sorry. image.jpeg
  13. Masscat
    Masscat Rookie
    Jan 2, 2016
    7
    0
    1
    WHAT SIZE DR DO YOU USE WITH THE LOWERED CAR
  14. Mo-par!
    Feb 21, 2016
    1,113
    550
    413
    Lebanon Valley PA
    Feedback is you can go with a 305 but you will need to heat-up and reshape the plastic inner fender on the drivers side. I'll be ordering 305's next week based on that feedback from other's on the forum...check out StellasHC.
  15. Burren
    Burren VIP Hellcat Member
    Apr 17, 2016
    199
    54
    98
    Same question for me; just moved to Houston and need reliable partners in the car world. If you're comfortable, I'd like to know who you use and trust. Thanks!
does a 2016 hellcat need modifications when installing eibach lowering springs
