Engine coolant levels
Discussion in 'SRT Hellcat Maintenance' started by shadowsk, May 24, 2016.
  1. shadowsk
    shadowsk SRT Hellcat Supporter Gold Supporting Member
    Mar 10, 2016
    433
    192
    113
    South Carolina
    Hi, I need some advice/help about my coolant level. A little back history..I overheated and lost all my coolant at 250 miles due to stuck thermostat. Dealership fixed and said only thermostat was replaced and that there were no busted hoses or anything. They said they performed a coolant leak test and no problems found. I've been monitoring my temps religiously since and everything seems fine.
    Last week I changed my oil and noticed the coolant level was down about an inch below the lower fill line. So I went and bought some coolant at the dealership and filled it up exactly to the lower fill line. The service manager said to keep an eye on it. So today I checked my oil and noticed the coolant level had dropped about a quarter inch. I've only drove the car twice since re-filling coolant and maybe have put 100 miles on it.
    Edit;I'm at 1070 miles now.
    My question is ...is it normal for the system to use a slight amount of coolant or should I take it in to get checked? I noticed a good bit of condensation in the reservoir is that normal as well? Thanks in advance. HC_Coolant1.jpg HC_Coolant2.jpg
  2. F6F-3
    F6F-3 SRT Hellcat Owner Hellcat Car Club Gold Supporting Member HCC Charter Member
    Feb 19, 2015
    848
    350
    Ga
    It appears you have a leak. I'd have it checked.
  3. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,640
    937
    Virginia
    Get it checked...closed system that should not be losing coolant
  4. Lord Hellcat
    Jan 6, 2015
    1,594
    712
    UK
    Agreed get it checked. You have a leak somewhere
  5. shadowsk
    Mar 10, 2016
    433
    192
    113
    South Carolina
    Thanks guys..Just made appt for 8:30 Thurs morning at a different dealership. I talked to the service manager and she said they had 2 good SRT techs. I'll report back our findings.
