Engine Knock
Discussion in 'Dodge Challenger SRT Hellcat' started by SRT707HC, Jun 16, 2016.
  1. SRT707HC
    SRT707HC Gold Member Hellcat Car Club
    Jun 25, 2015
    302
    178
    Mississauga
    Just thought i would share with you all my first and hopefully last horrified experience.
    Monday I had the oil changed in my Hellcat, 2700 km (1677 miles?). Car is 3 months old, and I'm about to leave for vacation to the USA
    Tuesday I decide to go out for a cruise around town... whilst leaving the local beer store I accelerated to change lanes and felt a shudder and then heard the knocking noise. I pull over and shut the car off, checked the oil level (which was ok). Started the car back up, looked at the oil pressure (seemed to be ok). Limped the car home less than 3 miles.. Had the car towed to the dealer... they spent most of Wednesday trying to figure out the knocking noise.
    Dealer called Wednesday late afternoon to say that they had to bleed air out of the oil galleries and that now the engine knock is gone. They said that one of the lifters may have gotten an air pocket and that's what caused the engine knock..
    Has anyone else experienced this??
  2. RDLSRT
    RDLSRT Silver Member
    Oct 17, 2014
    696
    172
    Houston Texas
    Never heard of that.
  3. SRT707HC
    Jun 25, 2015
    302
    178
    Mississauga
    The dealer said the same thing, that's why I reached out to Hellcat Forum, see if anyone else has had the same issue.
  4. 392shaker
    392shaker Silver Member
    Nov 17, 2015
    107
    108
    183
    Stoney creek Ontario
    What I have done in the past and currently do to my cat is do what is called "clear flood mode" you place the throttle to WOT and hit the start button. the engine will crank for about 15-20 second while this is happening monitor the oil pressure. it should climb. once it stops cranking start the car as you normally would. this will pre lube the engine without causing any unnecessary premature wear. This should also be done before you start the engine after you do a oil change and maybe priming the oil filter will lessen the time to build oil pressure.
    • Useful Useful x 5
  5. Hellcatmichael
    Hellcatmichael SRT Hellcat Supporter Gold Supporting Member
    Oct 20, 2015
    1,024
    315
    What you talking about Willis? No really the car won't start if you try starting it WOT then after 15seconds it stops by itself or do you stop cranking it. I'll tell ya they say there's nothing new under the sun but you learn something new every day? What does WOT mean? That's to the floor right? I'm stupid so excuse me.
  6. Link
    Link Silver Member
    Jan 27, 2015
    922
    210
    WOT wide open throttle
  7. oilburner
    oilburner Gold Member
    Nov 23, 2015
    253
    105
    coboconk ontario
    the hydraulic lifter has a plunger inside that the oil pressure keeps in place . sometimes that plunger can stick in the bore causing slop in the valve train giving that metallic knocking noise. use to get valve lifter noise a lot after installing a motor that sat unused for long time. oil filters should be filled an soaked in before install but most guys won`t take the time. it may never happen again. don`t worry unless it continues to be a problem. not that unusual. a little spec of crap could cause that plunger to stick, very close tolerance between plunger an lifter body.
  8. CanHP
    CanHP Silver Member
    Mar 23, 2015
    323
    123
    Mississauga Ontario
    Glad to hear that nothing was wrong, are you heading out on Friday?
  9. Hellcatmichael
    Oct 20, 2015
    1,024
    315
    So do you recommend doing the "clear flood mode " thingy ?
  10. 392shaker
    Nov 17, 2015
    107
    108
    183
    I do it once a week because i do not drive it every day so it has worked for me for many years. Once you build a few engine you will understand the importance of doing this. I did this when I work for GM on a many Corvette and CTS-V and never had any issues
  11. oilburner
    Nov 23, 2015
    253
    105
    coboconk ontario
    if you fill filter let oil soak into the filter an fill again till it can`t absorb any more, pressure will be instant. then no need for clear flood mode.
  12. SRT707HC
    Jun 25, 2015
    302
    178
    Mississauga
    10-4 yea sir
  13. SRT707HC
    Jun 25, 2015
    302
    178
    Mississauga
    I also have my 310T-310S and have done many engine rebuilds! I've had a few issues with lifters not filling with oil...
  14. Catless
    Catless Silver Member
    Feb 2, 2015
    1,045
    217
    198
    Parkersburg, WV
    To the original question. I have never heard of that on any engine "bleed the air out of the oil galleries". I wonder if they filled with the wrong oil say the standard 0W-20 and then changed to the required 0W-40. Or more likely they were cranking/testing it and the noise went just went away.
  15. SRT707HC
    Jun 25, 2015
    302
    178
    Mississauga
    That's what I was thinking...I don't see any oil charged out on my warranty invoice..
2015 challenger prelube
