engine temp fluctuation
Discussion in 'Dodge Challenger SRT Hellcat' started by huggytree, Apr 1, 2015.
  1. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,149
    753
    628
    i 'think' i can smell coolant when i have my ventilation system on.......i also 'think' i could smell it a few times when i walked in front of the car....other times i cant smell it............im not sure if im smelling the new duct work or a coolant leak....
    that being said.....noticed tonight while driving the HC around that the temp goes up and down.....when driving its below the center mark....when sitting at idle for long stop lights i see it go a bit over the 1/2 way mark.....is this normal?.......at long idle it does stop rising a bit over the 1/2 way point.....im just not used to seeing any fluctuation during normal around town driving...its 70 degrees here today
    my coolant level looks just fine in the storage reservoir.....so its not like im low on coolant
    notice when the car is turned off there's TONS of heat coming out of the hood scoop and extractors...yet the center of the hood is cool to the touch
  2. DGatzby
    Jan 16, 2015
    3,708
    1,982
    748
    Twin Cities, MN
    HT look at the performance page - gauge one. My coolant temp stays between 199-203. The oil temp on mine can vary a bunch when the car is run hard. But that coolant temp has been pretty steady, see what that looks like on yours. The dial on the side is near worthless.
  3. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    If you can smell it, you have a leak somewhere. After a decent drive, park it, pop the hood and get in there with a flashlight and hunt for it.
  4. B5 Blue
    1,747
    That doesn't work on a very slow leak if at the engine as the heat burns it off. For that it needs to be cold and a coolant pressure tester used
  5. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    You should not be able to smell it, trust your nose, you know, your a car guy.
  6. MVT
    MVT Gold Member
    Jan 11, 2015
    1,084
    311
    I noticed, being from Illinois the the coolant and oil temps do go up now because we have the weather warming up. The temp will go up a bit on idle and when your moving it goes down because of the air flow.
    Mine sitting in traffic bumped up to 226 but then went to 218 when I got moving. The longer your moving everything goes down further.
    As for the hood they designed it that way, the hot air goes out the heat extractors and the center scoop is like a funnel so cooler air can come in and cool the top of the supercharger.
    As for the coolant smell, watch to see if when sitting any drops are on the ground. It could be from the motor heating up, some gases come out of the over flow tube on the coolant over flow tank.
  7. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    You're not seeing things huggytree, it happens to me too the idle then temp rises above the center mark so it's normal. It goes away fast as soon as I start driving and seconds later it drops below the center mark. When turned off it dissipates a lot of heat for me too.
  8. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,452
    953
    668
    Cape Coral, SW Florida
    My 08 was annoying in Florida before the 180-185 thermostat swap and fan temp settings change. No need for an engine to get that hot. All these electronics and sensors and the thing can't figure you're stopped at zero mph and kick on the fans. Instead it sits there and cooks itself.
    • Agree Agree x 3
  9. MVT
    MVT Gold Member
    Jan 11, 2015
    1,084
    311
    Its a Hemi with a Huffer on its back, its goona get hot!:eek:
  10. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    HEMI POWAH
  11. Blackdevil77
    Blackdevil77 Silver Member
    Feb 1, 2015
    538
    133
    Long Island, New York
    You definitely have a leak somewhere, same exact thing as you describe happened to my Pontiac G8 GT. Although, with my G8, it was the head gaskets causing combustion gases to seep into the coolant, causing it to overflow out of the overflow o_O
    You definitely don't have that problem, but there is certainly a leak somewhere and the fact that the temp does that when you stop means you are a bit low on coolant. Check all your coolant lines and radiator hoses.
  12. DGatzby
    Jan 16, 2015
    3,708
    1,982
    748
    Twin Cities, MN
    That don't sound right. I would watch that one also. Monday near southern Iowa, 80 degrees running the hell out of it, idle, cruise it don't matter my coolant does not show that much deviation on the coolant gauge. Oil temp yes, coolant no. Think about it ...27 degree coolant temp deviation?? 199-226
  13. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    Wasn't there a possible issue with one of the o-rings in the SC that was causing a very slow leak.
    I believe it was allowing coolant to get into one of the cylinders
  14. charlotte HC
    charlotte HC Hellcat Member
    Mar 30, 2015
    33
    23
    i was at the dealer yesterday to install drag radials and they replaced a radiator clamp per recall. See dealer code/explanation below.. dealer.JPG
  15. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,383
    768
    Slinger Wisconsin
    It's not a recall
challemger hellcat temp gauge problems
dodge charger srt8 2015 coolant temperature
hellcat running temperature
hellcat temperature variation
oil temp on 2016 dodge dart
srt engine coolant temp
why does my hellcat coolant somehow has air
why is my car getting hot and my coolant hoses hard in my hellcat challenger
