Eric's build m6 HHP tune,b woody ,metco 2.85 ,180t stat
Discussion in 'SRT Hellcat Builds' started by gto19, Jan 13, 2016.
  1. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    image.jpeg image.jpeg image.jpeg image.jpeg i thought I'd document with you guys my car and what I've done to her since I've got it in September.i love this car!so I've basically done what most you have done by installing a metco 2.85 pulley,b woody intake ,180 t stat,springs ,Barton shifter
    Today me and a friend of mine who is a great mechanic in San Jose did The pulley ,springs then dyno .oh ya a great lunch at the local BBQ joint next store.we were hustling today,busy
    • Like Like x 3
  2. TrackDay
    TrackDay Silver Member
    Mar 28, 2015
    988
    271
    173
    What tool did you use to remove the wiper arms before pulling the cowl? I removed mine using a battery terminal puller but it was not easy at all. I assume I need a different tool to make it easier next time.
  3. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    image.jpeg The pulley swap was easy for my buddy.i was his helper.i would say separating the stock pulley from the snout was the hardest.it takes some muscle to get that sucker off.you can see the piece of steel we used to put in between the pins.if I had time I would have made a jig to go over every pin so the load would be distributed over all pins instead of two pins ,maybe metco will make something in the future
    image.jpeg image.jpeg image.jpeg image.jpeg More pics
  4. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,668
    2,027
    Please keep us updated,, maybe a step by step,,, had the wipers, cowl removal,, supercharger lid, how you got the pulley off, and if you had any pressure issues doing the T-stat,, maybe there is a trick to make the job easier.. And part number.. Either way, looking forward to seeing your results
  5. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    image.jpeg View attachment 33622 View attachment 33623 View attachment 33623 View attachment 33622 So we had one very strange issue .when we got the new pulley on we went to install the snout back to the super charger with the six long bolts and when we'd tighten them the pulley would bind and not spin !!WTF !!
    Well for some reason the bolt that you see in the middle of the 7 pins was loose!! And had spun out at least a 1/16 of a inch and was hitting the bolt on other part where it susspose to mate to.i do not know why that bolt was loose or if had been loose since I bought the car.we don't know .we did nothing to loosen that bolt.so anyways we removed the bolt and lock tighted it and we're back on are way
    • Useful Useful x 2
  6. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    Wipers and cowel come off very easy ,for the wipers just pop those plastic covers off with your finger nails ,used no tool then used a socket wrench to remove the wipers .theres two little white lines on your windshield to align then back up when you reinstall
  7. hellcat1
    Sep 27, 2014
    10,668
    2,027
    Any issues with the T-stat change, like air pocket in the system?
  8. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    image.jpeg This tool will remove will remove the plastic cowl ..very easy.you just pop off the plastic pins with it.just take your time.now remember guys my buddy is a excellent mechanic .i could've never done this by myself or if I did it would've taken me 2 days at least .he has awsome tools to make this job very easy
    • Useful Useful x 2
  9. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    I did the T stat about 2 months ago by myself,20 minute job .if I remember I just put a big ziplock bag under the housing to catch whatever coolant I could .loosend the two bolts pulled the hose outta the way .popped the t stat out noting the position of it and just put the new one in and retightened everything back up.put the coolant back in from the ziplock and added some water wetter to make up the difference from what I lost.very easy
    • Useful Useful x 2
  10. hellcat1
    Sep 27, 2014
    10,668
    2,027
    So no vacuum leak, or any other crazy things that could cause a issue?
  11. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    image.jpeg image.jpeg image.jpeg image.jpeg View attachment 33627 View attachment 33627 Mopar Springs .my buddy made this job look even easier! We cut half a coil from the back .i bought them off amazon.car looks sick now .rides exactly the same from what I can tell
  12. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    Oh ya .we also put the Nitto tires on today
  13. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    Nope .vaccum leak where? Car is running cherry .no codes nothing
  14. hellcat1
    Sep 27, 2014
    10,668
    2,027
    I thought I read that you had to vacuum seal the system so to not get air in it...so basically it's like changing it on an older v8
  15. gto19
    gto19 Silver Member
    Aug 18, 2015
    500
    146
    We dynoed today .i will make a data log Tommorow and send my results back to josh at HHP .maybe he tweak the tune ..who knows .remember I'm out in California so my tune is for 91 octane.i think we can get more out of her!
    • Useful Useful x 2
hellcat car surges on cold start
hhp racing hellcat
