Factory Fog Lights
Discussion in 'Dodge Charger SRT Hellcat' started by GhostHellcat, Jul 9, 2015.
  1. GhostHellcat
    GhostHellcat Hellcat Member
    Jun 30, 2015
    57
    Va
    Does aybody know if the SRT FogLights will plug and play a our front ends?
  2. dodgeboy
    dodgeboy Silver Member
    Dec 31, 2014
    344
    113
    You know there is a cooler behind the location (both sides) where the fog lights are on the 392, right? You don't want to cover up that grille.
  3. GhostHellcat
    Jun 30, 2015
    57
    Va
    Thanks for SA. I had heard rumors that the 2016 model was going to have Fog Lights.
  4. dodgeboy
    Dec 31, 2014
    344
    113
    Interesting. Hadn't heard that yet. If that's the case, maybe there will be a redesigned front end? Or a fog light that is ventilated somehow? Either way, the way things are today (2015 model year), you don't want to plug up those holes with fog lights. One side has an oil cooler, and the other side has an auxiliary charge air cooler (intercooler, basically) that need air.
  5. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,032
    I haven't heard anything about fog lights on a hellcat,, cooling is a huge issue,,I don't think they want more issues trying to cool this car..that being said,stranger things have happened..
  6. 4510
    May 13, 2015
    729
    163
    Arizona
    The Auxiliary charge air cooler... does the intake charge actually pass through this cooler or is it an air to liquid arrangement to help cool the coolant sent through the intercoolers in the S/C?
  7. dodgeboy
    Dec 31, 2014
    344
    113
    A separate loop of coolant (specifically to cool the intake air charge) flows through this cooler, and the larger cooler (center of the front of the vehicle), as well as the two coolers int he supercharger itself. There's an electric pump that moves this coolant through the system. The intake charge itself doesn't move through this cooler. It's just used to cool the coolant so that when it passes through the supercharger it is at a lower temp.
    I can't find the more detailed video, but this video touches on how the system works: It just doesn't go into as much detail as the other video that I can't find.
  8. 4510
    May 13, 2015
    729
    163
    Arizona
    Thanks! The reason I ask, is on my other S/C cars, the Intercooler has to have the intake air charge flow through it or around it. In an air to air intercooler the intake charge flows through the intercooler while ambient air passes around the intercooler. In the water to air, the water flows through the intercooler and the intake charge passes around it. Thus, what we have is two water to air intercoolers in the S/C. The parts of the system out front are I believe heat exchangers. They don't handle the intake charge, they cool the liquid that is piped through the intercoolers to cool the intake charge.
  9. dodgeboy
    Dec 31, 2014
    344
    113
    Exactly right. You can also monitor the temperature of the coolant in that loop, with the gauges in the I/P and in the SRT Performance App pages.
  10. cjohn7
    cjohn7 VIP Hellcat Member
    Apr 13, 2015
    122
    59
    98
    from what I've heard the 2016 fog lights will be integrated into the front splitter, and not the actual front bumper.
2016 hellcat getsvtog lights
adding fog lights to hellcat challenger front
can fog lamps be added to hellcat
charger hellcat with fog lights
fog light on hellcat
hellcat challenger fog lights 2016
no fog lights on hellcat challenger
why does my hellcat coolant somehow has air
