Fault Code P00FB
Discussion in 'Dodge Challenger SRT Hellcat' started by phil hunter, Jan 1, 2016.
  1. phil hunter
    phil hunter Hellcat Member
    Sep 23, 2015
    85
    17
    Just bought a new Plum Crazy Challenger Hellcat automatic. On the way home the Malfunction Indicator (MIL) Light came on along with the Electronic Throttle Control (ETC) light. Can not get them to turn off. Checking the diagnostics, it shows code: P00FB. Any idea what this code is?
    Thanks,
    Phil
  2. FarAwayFromHere
    FarAwayFromHere Gold Member
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    WARRANTY
    Oh Boy...Ouch....
    Bummer Dude...
    Dealer repair!
  3. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,063
    306
    Looks like the TMAP sensor on the driver's side of the supercharger on the lid is reading high.
    • Useful Useful x 2
  4. fnkychkn
    Jan 24, 2015
    1,491
    606
    greasy cardboard box
    P00FB-SUPERCHARGER/TURBOCHARGER OUTLET AIR PRESSURE SENSOR 1 CIRCUIT HIGH
    Theory of Operation
    [​IMG]
    COMPONENT LOCATION / CORRELATING PRESSURE SENSOR DTCS / CORRELATING TEMP SENSOR DTCS
    BARO SENSOR Inside the PCM P0109, P2227, P2228, P2229, P3032 N/A
    Mass Air Flow (MAF) Sensor Before the Throttle Body P0102, P0103, P1613 P0111, P0112, P0113
    Throttle Outlet Pressure (TOP) Sensor Between the Throttle Body and Supercharger P0069, P012A, P012B, P012 C, P012D, P1613 P0096, P0097, P0098
    Intermediate MAP (IMAP) Sensor On the Intake Manifold directly after the Supercharger P00F8, P00F9, P00FA, P00FB, P0607 P00E9, P00EA, P00EB
    Bank 1 MAP Sensor Right side of the Intake Manifold P0105, P0106, P0107, P0108, P0607 P07B, P007C, P007D
    Bank 2 MAP Sensor Left side of the Intake Manifold P2A0A, P2A0B, P2A0C, P2A0D, P0607 P00A1, P00A2, P00A3
    NOTE: The MAF Sensor and each of the four MAP Sensors also have an integral air temperature sensor. The temperature sensors have a 5.0 volt signal circuit and share the sensor ground circuit with the pressure sensor. They do not share the 5-Volt Reference circuit with the pressure sensor and therefore operate as a typical two wire temperature sensor.
    The 6.2L engine uses several sensors to monitor the air pressure and temperature throughout the intake air system. The PCM uses this information to help calculate fuel delivery, ignition timing and Supercharger control. The PCM runs diagnostics to check the rationality of the sensors. The Supercharger Inlet Pressure Sensor is the centralized sensor in the system and is the main sensor used for the rationality diagnostics of the airflow before and after the Throttle Body.
    Individual MAP/Pressure Sensor rationality diagnostic checks:
    • At ignition on, engine not running, the BARO Sensor and four MAP/Pressure Sensor input signals are compared. If one of the MAP/Pressure Sensor input signals has a difference of more than a calibrated threshold from the others, a performance fault is set against that sensor.
    • With the engine running, the input signals of the three MAP/Pressure Sensors that are downstream of the Supercharger Inlet Pressure Sensor (Supercharger Outlet Pressure Sensor, Bank 1 MAP, Bank 2 MAP) are compared. If one of the sensor input signals has more than a 10.0 kPa (1.5 psi) difference from the other two, a performance fault is set against that sensor.
    BARO/Supercharger Inlet Pressure Sensor rationality diagnostic check:
      • The Supercharger Inlet Pressure Sensor signal is compared to the BARO signal to check rationality of the sensors. During natural aspiration, the Supercharger Inlet Pressure Sensor signal cannot be greater than the BARO signal plus 10.3 kPa (1.49 psi). During boost conditions, the Supercharger Inlet Pressure Sensor signal and BARO signal pressures should be similar. If the diagnostic fails during a drive cycle, a fault is set (P0069) and the secondary Supercharger Inlet Pressure Sensor rationality diagnostic is run to determine which sensor is irrational.
    MAF/Supercharger Inlet Pressure Sensor rationality diagnostic check:
    • This diagnostic runs continuously, unless any airflow, throttle, MAF, BARO, or Supercharger Inlet Pressure Sensor diagnostics have failed. Then using the pressure differential across the throttle opening (BARO - Supercharger Inlet Pressure Sensor), the PCM models the mass air flow volume through the Throttle Body. This modeled value is compared to the actual MAF Sensor signal input to the PCM. If the difference is greater than a calibrated threshold, a fault is set (P1613) and the secondary Supercharger Inlet Pressure Sensor rationality diagnostic is run to determine which sensor is irrational.
      • If either of the first two diagnostics fail during a given trip, or if one of the downstream MAP/Pressure Sensors is determined to be irrational, the PCM runs a secondary diagnostic to determine if the Supercharger Inlet Pressure Sensor is rational. With the engine in a natural aspiration condition (not boosted), the PCM compares the signal input from the Supercharger Inlet Pressure Sensor to the signal inputs from the Supercharger Outlet Pressure Sensor, Bank 1 MAP, and Bank 2 MAP Sensors. If the Supercharger Inlet Pressure Sensor is not within a calibrated threshold of the other three MAP/Pressure Sensors, it is determined to be irrational and a fault is set (P121B).
    Temperature sensor rationality checks:
    • After a cold soak of the engine, the Engine Coolant Temperature (ECT) and Ambient Air Temperature (AAT) Sensor inputs are compared to the inputs form each of the temperature sensors located in the MAF and MAP Sensors. If a temperature sensor is not within a calibrated threshold of the ECT or AAT Sensors, a performance fault is set.
    [paste:font size="4"]When Monitored and Set Conditions
    When Monitored: This diagnostic runs continuously when the following conditions are met:
    [/paste:font]
      • With the ignition on.
      • Battery voltage greater than 10.4 volts.
    Set Conditions:
    • The Supercharger Outlet Pressure Sensor input voltage is above the maximum acceptable threshold.
    Default Actions:
      • The MIL light will illuminate.
    Possible Causes
    5–VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
    SUPERCHARGER OUTLET PRESSURE SIGNAL CIRCUIT SHORTED TO VOLTAGE
    SUPERCHARGER OUTLET PRESSURE SIGNAL CIRCUIT SHORTED TO THE 5–VOLT SUPPLY CIRCUIT
    SUPERCHARGER OUTLET PRESSURE SIGNAL CIRCUIT OPEN OR HIGH RESISTANCE
    SENSOR GROUND CIRCUIT OPEN OR HIGH RESISTANCE
    SUPERCHARGER OUTLET PRESSURE SENSOR
    POWERTRAIN CONTROL MODULE (PCM)
    • Useful Useful x 4
    • Winner Winner x 2
  5. 1FSTCAT
    1FSTCAT The Punisher
    Dec 28, 2014
    1,129
    407
    358
    Virginia
    Just looked at all of your posts, why are you in this forum if you don't have a Hellcat? You clearly have a lot of time to track all of the issues and comment on them here.
    Guy gets a new car posts for helps and you respond as you do...I don't get it. If you have issue with the car, take it out on FCA. Not sure what it takes to ban someone here, but I hope you're on the short list. Seriously, contribute and encourage, but the shot to the nads in every post is just sad.
    • Agree Agree x 3
  6. RichCat
    RichCat Hellcat Member Hellcat Car Club HCC Charter Member
    Jul 14, 2015
    73
    13
    Foxboro, Ma.
    Hi,
    Not sure what is really going on but something I would try is to unplug and reconnect the sensor on the
    top driver side of supercharger housing…carefully to see if it is possibly a bad connection. And wiggle
    some of the wiring around the MAP sensor area on the driver side of the intake tube.
    RicH
  7. Steven_sbs
    Steven_sbs Browncoats Unite Gold Supporting Member
    Dec 18, 2014
    843
    345
    South Jersey
    Where would we be without you? Nice post.
  8. phil hunter
    Sep 23, 2015
    85
    17
    For those who offered help, than you.
    Phil
    • Like Like x 3
  9. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,599
    451
    368
    Henderson, NV
  10. Viperjock
    Viperjock Rookie
    Jul 14, 2015
    16
    5
    I have the same problem. I have already been to the dealer once. Just got the light again today.
  11. Viperjock
    Viperjock Rookie
    Jul 14, 2015
    16
    5
  12. Viperjock
    Viperjock Rookie
    Jul 14, 2015
    16
    5
    Phil,
    What did you do to get this fixed? I went to the dealer last week. They supposedly fixed it. I just started my car up and got the ETC light.
  13. Danny123
    Danny123 SRT Hellcat Moderator Staff Member
    Oct 4, 2015
    670
    401
    image.jpeg I just got this one, wondering if it is caused by the race fuel I put in on Friday night at the track? Going to dealer Monday to have it fixed.
  14. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,339
    824
    Suwanee, Georgia
    I drove my car and so far no error. But I thought that P0420 was due to O2-sensor being dipped in the water
  15. clickr
    clickr Silver Member
    Apr 18, 2015
    339
    112
    did it rain on your car or did you wash it? Seems like some have reported problems around the connectors around the SC. Unplug them that you can find one at a time, see if there is any water. Put electrical tape on each plug after putting it together. hope you get it straightened out.
16 challenger code b222a-00
2015 dodge hellcat electronic throttle control light on
p00ea
p00ea dodge
p00fb
p0108 2016 hellcat
p012b hellcat
p012d
