Fault Code P0335?
Discussion in 'Dodge Challenger SRT Hellcat' started by Ken H, Mar 8, 2015.
  1. Ken H
    Ken H Rookie
    Dec 25, 2014
    28
    7
    Beverly MA
    My new Hellcat has been in winter hybernation mode for about 8 weeks due to our 105 inches of snow but today I started it to see if the clock needed to be reset because of the DLS time change. When I started it the engine immediately started and stopped, I assumed it was because it had been sitting in my garage (which is heated) I restarted it and it ran fine BUT it threw a P0335 engine code (why??), my car has less than 800 miles on it since I picked it up on Dec 31, 2014. Any help would be greatly appreciated. Thanks Ken
  2. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    May be crankshaft position sensor ? Low voltage issues... Hmmm I would call SRT customer service but I'm sure other members could chime in and confirm or it could it be something else
  3. goingsolo2
    Oct 29, 2014
    1,562
    642
    Long Island, NY
    P0335 Chrysler
    P0335 Chrysler - Crankshaft Position Sensor
    Possible causes
    - Faulty crankshaft position sensor
    - Crankshaft position sensor harness is open or shorted
    - Crankshaft position sensor circuit poor electrical connection
    - Signal plate may be damage
    - Starter motor may be faulty
    - Starting system circuit
    - Dead or weak battery
    [​IMG] What does this mean?
    Tech notes
    Sometimes and in some models, low battery voltage or a weak starter can can trigger a Crankshaft Position Sensor code. Before replacing any parts, recharge or replaced battery.
    When is the code detected?
    The crankshaft position sensor (POS) signal is not detected by the Electronic Control Module (ECM) during the first few seconds of engine cranking
    Possible symptoms
    - Engine Light ON (or Service Engine Soon Warning Light)
    - Possible lack/loss of Power
    - Engine may stall while driving
    P0335 Chrysler Description
    The Crankshaft Position Sensor (CKP) also known as the crank position sensor is an electronic device used in an engine to record the rate at which the crankshaft is spinning. This information is used by the Electronic Control Module(ECM) to control ignition and fuel injection. The sensor system consists of a rotating part, typically a disc, as well as a static part, the actual sensor.
    When the engine is running, the high and low parts of the teeth cause the gap with the sensor to change. The changing gap causes the magnetic field near the sensor to change. The change in the magnetic field cause the voltage from the sensor to change.
    • Useful Useful x 3
  4. goingsolo2
    Oct 29, 2014
    1,562
    642
    Long Island, NY
    My guess would be a very low battery from sitting. Hopefully that's it and it's a very simple fix!
    • Like Like x 3
    • Agree Agree x 3
  5. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    goingsolo2 you rock! Thanks for confirming
    • Agree Agree x 3
  6. goingsolo2
    Oct 29, 2014
    1,562
    642
    Long Island, NY
    Any time:) This place rocks!
    • Agree Agree x 5
  7. Ken H
    Ken H Rookie
    Dec 25, 2014
    28
    7
    Beverly MA
    Thanks everyone I put a charger on it and I'll start it again tomorrow and see what happens. Are codes like this self resetting or do I have to have a dealer erase the code? There's still WAY TO MUCH snow, ice and salt on the roads to chance a ride to the dealer it could be 3-4 weeks before I can take it to the dealer. Thank Again. Ken
  8. Big Rich
    Big Rich Hellcat Member
    Sep 17, 2014
    47
    13
    Palm Beach Gardens, Florida
    Ken,
    I had the same problem with mine. Started it in my garage last January, and it immediately turned off. Started right back up, but had code P0335. I was on my way to the dealer anyway to pick up the second black key that wasn't available when I picked up the car. My car had 900 miles on it. The dealer hook it up to diagnostics and it showed a bad "crank sensor". They got the part from their other dealer ship an hour a way, installed it, I was on my way in three hours total, never to have the issue again. If crank sensor doesn't think the engine is running (or has the crankshaft rotating) it cut the fuel pumps for safety I was told. Hope this helps... RIch
  9. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,699
    2,039
    You have me worried now,,I was going to start my car very soon, like Wednesday,I need to move it over so I have remove the wheels so I can them plated...
  10. 70TA-09RT
    70TA-09RT Rookie
    Nov 4, 2014
    14
    5
    Cleveland, Ohio
    Ken H, I would suggest to put a battery tender on these cars if your going to let them sit for a prolonged period of time as the system never really goes to sleep and this will cause your battery to discharge.
  11. tsc
    tsc SRT Hellcat Enthusiast
    Oct 27, 2014
    1,536
    751
    563
    Cincinnati, OH
    That, and put the car in shipping mode as it puts less draw on the battery as all but essential systems are turned off. :)
  12. B5 Blue
    1,746
    The dealer most likely put a crank sensor on to make money, they don't get paid to charge battery and clear code. If it was bad it cranks no start. Put a charger on it due to low BAT. I don't know how to clear DTC sorry let's ask our community or DocBuick
    Let it sit till salt is gone
  13. Big Rich
    Sep 17, 2014
    47
    13
  14. MVT
    MVT Gold Member
    Jan 11, 2015
    1,084
    311
    I bet its the battery. I start or move mine under two weeks befor the car goes to sleep. I heard two weeks and she goes into the deep sleep.
  15. Zacuda
    Zacuda Silver Member
    Oct 10, 2014
    264
    78
    Chicago, IL
    I saw this and went over to my sleeping cat and put on the battery tender. Thanks for the reminder. About one month to go here in Chicago before the car is released for spring!
fault codes for 2015 dodge challenger
hellcat code p 112d
hellcat p0335
p0335
p0335 code dodge dakota
p0335 code self clear
reset this code p0335
ve 09 ss p0335
