First oil change SURPRISE
Discussion in 'Dodge Challenger SRT Hellcat' started by moparjim, Jan 10, 2017.
  1. moparjim
    moparjim SRT Hellcat Supporter Gold Supporting Member
    Nov 8, 2016
    1,776
    2,330
    683
    Quebec,Canada
    So I finally got a chance to change the oil for storage last week. Received race ramps thanks to the forum for the help.
    Anyways after taking off the covers I noticed that the filter was dripping oil and there was oil on cooler lines. While wiping of the oil I managed to turn the filter. I was able to unscrew the filter with zero force not much more than turning a tap.
    I mean if I had been able to keep driving it I believe it could have vibrated off.
    Did not notice any oil leak on floor because of the covers but did have to clean a bit of a
    mess under the car in that area.
    Now the dealer didn't change the oil the car was built 08/16 and was received at the dealer in Sept. I picked up the car Oct.18. With 5kms. on it so why would they.
    I just thought I would share this unsettling experience I may be the only one but some may want to check there new cars mine has 400 miles on it.
    Hope this helps someone.
    • Useful Useful x 2
  2. Johntpr
    Johntpr VIP Hellcat Member
    Aug 10, 2015
    111
    46
    98
    Rockland County, NY
    You should also check the oil cooler drain plug fitting. Many have reported it to be very loose as well.
  3. moparjim
    Nov 8, 2016
    1,776
    2,330
    683
    Quebec,Canada
    It was on good unlike the drain plug that was on stupid tight.
  4. fltru103
    fltru103 VIP Hellcat Member
    Jul 30, 2016
    273
    91
    98
    Southern New Jersey
    Mine was very loose. I was surprised and could have taken the plug off by hand, but the rubber o-ring kept it sealed. No leaks anywhere.
    The oil filter required an oil filter wrench to loosen it up.
    Mileage at change was 1100.
    All this points out to very poor PDI at the dealer. Things that should be inspected and verified by the shop before delivery.
  5. MABBRYFL30
    Feb 10, 2016
    7,944
    5,579
    1,163
    That is interesting and thank you for sharing this. Something to look out for.
    Good catch on your part!!!
  6. MAXKILLS
    MAXKILLS Senior Hellcat Member
    Aug 15, 2016
    307
    54
    Thank you for this information, Currently have 800 miles, I will be checking my oil filter and drain when I get home from work. I will post the findings....
  7. MABBRYFL30
    Feb 10, 2016
    7,944
    5,579
    1,163
    Do your tires get flat spots from being in storage?
  8. moparjim
    Nov 8, 2016
    1,776
    2,330
    683
    Quebec,Canada
    I guess I'll find out in spring but I think ill be good I aired up the tires and park the car on rubber parking pads. It's what my stepfather used to use to store his BMW's on. When I drove my mothers 645 home from Ontario there was no vibration so I should be good too. Fingers crossed. They are softer than the tire so they give first. P_20170108_160713_vHDR_Auto.jpg
    • Useful Useful x 3
  9. BULL
    Nov 20, 2014
    3,968
    1,361
    Two things,
    Do you have a link for your TireCradles? I've been looking for some, but all I can find are priced at a point that seems, silly?
    As for the loose filter, I seem to recall several people mentioning this filter condition with their first oil change. It's not ideal, and not right, but also not an entirely uncommon occurrence.
  10. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    3,055
    1,513
    498
    Virginia
    Good catch...
    Did my initial at a little over 1800 miles. Filter tight (needed end cap wrench), oil pan drain a little over tight, oil cooler barely snug.
    sounds like poor PDI. with such low mileage, you might want to go back over it and look for any other gifts that might have been left for you
  11. moparjim
    Nov 8, 2016
    1,776
    2,330
    683
    Quebec,Canada
    Bull I just looked them up quickly and found them at 350 USD and in Canada 450can. Either one seems expensive but they do seem to me to work as advertised.
    I didn't buy them just sadly inherited them. I don't know when or where they got them from.
  12. fltru103
    Jul 30, 2016
    273
    91
    98
    Southern New Jersey
    I use the flatstoppers. Race ramps has them. Yes, I think they are expensive. As for what they do, I'll know when the salt is no longer on the road.
    As for loose filters or drains, all part of PDI inspection that each dealer gets paid to do. Problem is, the low paid B or C class tech doesn't get much anyway, so most just don't care to check everything on the list.
  13. BULL
    Nov 20, 2014
    3,968
    1,361
    I guess I can't debate whether or not checking the tightness of the oil filter is on the PDI list or not, but I would be surprised if it was.
    Consider that our engines are supposedly each dyno tested and delivered with that oil/oil filter in/on them. I would think that it would need to be properly installed at that time. Even if not, I'd still be surprised if subsequent to that event that the tightness of the filter was on a check list.
  14. moparjim
    Nov 8, 2016
    1,776
    2,330
    683
    Quebec,Canada
    I agree with you that they probably didn't check the filter. Another thing I notice is the cover with the 4screws was over tightend to the point that the washers were bent. Factory or dealer I don't know. But my wife's 15 charger 5.7 they are fine.
    I must say it pissed me off to the point it took me a couple of days to post. Mostly to control use of colorful language.
    Btw did you see I responded to your question about the tire cradles. Sorry I don't have more info. I have my Grand national on wheel solids which are curved somewhat but I like these better. Up here in Canada either one is expensive unfortunately.
    I'm not sure the how much the flat stoppers go for but maybe worth looking into also.
  15. moparjim
    Nov 8, 2016
    1,776
    2,330
    683
    Quebec,Canada
    I was thinking the same thing last night.
    Oh well I have a couple of months to get friendly with it till spring comes.
