First trip to track
Discussion in 'SRT Hellcat Racing Forum' started by Deputydog, Jun 27, 2015.
  1. Deputydog
    Deputydog Gold Member
    Nov 2, 2014
    1,002
    261
    Spokane, Washington
    So I took my Cat to the local Friday night street drags to see how it would do. I put on a set of Nitto 555's (305's) but I could not get these to hook up at all.
    I made 4 runs. Best time was my first at 11.7 @119 mph with a 1.87 60" (tires were at 32 psi). The other 3 runs were horrid 60' times since I was just spinning.
    I dropped tire pressure to 20 psi and it seemed worse (as far as spinning). I thought I gave them plenty of time in the burnout.
    I turned off traction control, and ran in sport mode. I know the track prep was bad, at least I heard lots of grumbling about that from others, plus it was 100* out.
    So what am I doing wrong?
  2. B5 Blue
    1,745
    How long was your burnout? Needs to be at least 5 seconds from what I've heard for Nittos. 20 psi is right. For grins did you try street mode to check 60 foot?
  3. Deputydog
    Nov 2, 2014
    1,002
    261
    Spokane, Washington
    It was probably 3 seconds I think. I did try street mode, seemed to shift better but still spun.
    There was a '15 c7 Vette running 11.4's, but never got a chance to line up against him. A couple '15 GTR's there too, running 10.8's.
  4. buddyg
    buddyg Gold Member
    Oct 24, 2014
    1,331
    679
    563
    Michigan (West Coast)
    I have the same tires and they need a John Force burnout 3 seconds is not nearly enough. Pressure at 18 and the track prep needs to be good. I ran 10.8 at 126 mph with them.
  5. B5 Blue
    1,745
    Can you talk like him after a win?
  6. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,128
    742
    congrats...you did .1 better than me on the first try...im assuming a A8?
    i had no issues with grip....stop flooring it....ease it down more.....my first run was 11.8 , but i got a higher mph than you......i also have the same tires and did not do long enough burnouts....also left tc on
    i think you should be thrilled with 11.7!! and if you have a M6 i REALLY think your doing good!
  7. pink68
    pink68 Silver Member
    May 27, 2015
    248
    89
    178
    Birmingham Alabama
    Are the Nittos different than the BFG Drs? Normally a DR needs a shorter burount to clean them off and slightly heat. Over heating leads to small balls of rubber pilling on the surface which can act like little greasy ball bearings. On my other brand car with DRs I do a 2nd gear 2sec burnout at 4000rpm shifting to 3rd (auto) then letting the car rollout but not past the tree obviously. That car runs 10.25 @ 135 and hooks very nicely.
    p.s. Edit - I also avoid a lot of water
  8. Deputydog
    Nov 2, 2014
    1,002
    261
    Spokane, Washington
    Thanks huggy! I have the A8..
    Funny though, several subsequent runs were around 11.9 with trap speed of 121 or 122.
    I hoped to get one good run in and get close to a 10.xx time. Oh well, I had fun on my first trip out..
    Anyone know how to get the little rubber chunks off my rear fenders now? LOL
  9. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
    A lot of people use painters tape and not the cheep stuff image.jpg before hand !
    I would try WD40 to get the tar off
  10. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    806
    563
    If you would've sprayed it down wit some spam would've washed right off
  11. B5 Blue
    1,745
    Gotta love auto correct or I need to go to grocery store:D
  12. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    806
    563
    Grocery store I meant spam cooking oil spray wipes off wit water but can't sit over night at track they always have water so you can do between passes or on way home I usually do about three passes rinse off psi up and drive home
  13. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    806
    563
    When your new drag radial and wheels come in you gonna need to do about three little burn outs the correct way to measure which psi has biggest contact patch on your set up put spam on the whole rear fenders and you see you be cracking up but don't be shy spray a lot and rinse off don't don't don't let sit over night or you and wd40 or any oil product wit lots of massaging
  14. B5 Blue
    1,745
    I'll let you know when the meats come good info thanks
  15. B5 Blue
    1,745
    Regular burn outs or line lock burnouts?
