Fixed my rattling trunk lid
Discussion in 'Dodge Charger SRT Hellcat' started by dodgeboy, Jul 26, 2015.
  1. dodgeboy
    dodgeboy Silver Member
    Dec 31, 2014
    346
    114
    Since I got my Charger Hellcat, I've been annoyed/disappointed with how the trunk sounds when it is closed. It's always sounded like it was going to fall apart every time you closed the trunk lid. It made a loud rattle/bang sound. A week ago, while washing the car, I noticed that if I pressed down on the outside edges of the spoiler, that there was quite a bit of play. I could make it "rattle" by pushing down, or back/forth at the ends of the spoiler. After a little investigating, I found out that there is a 10mm bolt just inside the trunk lid on both sides, that holds down the ends of the spoiler. Both of those bolts were loose on my car. It didn't even require a full turn of the bolt to snug things up and completely cure the rattle. The bolts are located behind a rubber/plastic trim piece that you can see in the photo below. I couldn't figure out how to remove that trim piece without breaking it, but I was able to wedge a small ratcheting-end wrench (10mm) in there to do the job just fine. I hope this can help someone else that has the same problem!
    • Useful Useful x 7
  2. DNTBTHR
    DNTBTHR Silver Member
    Dec 4, 2014
    367
    77
    I will try as mine rattles as well
  3. B5 Blue
    1,745
    Thanks for posting this!
  4. butterscotch71
    butterscotch71 Hellcat Member
    Nov 22, 2014
    74
    13
    The nuts holding the spoiler on my 09 Challenger used to loosen up regularly. I finally gave up and put a little thread locker on them!
  5. Jefe
    Jefe VIP Hellcat Member
    Aug 29, 2016
    993
    335
    93
    AZ
    Heard my spoiler rattle yesterday so I popped the trunk and looked behind those plastic covers. No bolts on either side for some reason. After spending 20 minutes trying to get the covers off I gave it too much pressure and broke a couple tabs. Put 2 bolts in and fixed the rattle and was able to get the covers back on but anyone know how these come off without breaking?
2016 dodge charger trunk rattles
rattle when trunk lid is closed
what is in hellcat trunk
