Float charger for battery
Discussion in 'SRT Hellcat Maintenance' started by 7777.775, Jan 5, 2015.
  1. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,460
    768
    Need opinions or facts if it is ok to use a float charger on the battery and have it hooked up, then close the trunk? Any risk of explosion or fire due to the battery being in an enclosed area? I'm wondering if you can connect the float charger to the jumper terminals under the hood and if that would be safer? Not sure if that would work or not, maybe just keep the trunk open? Then I'd have to see if the trunk light would just time out.
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,688
    2,038
    I don't see an issue with putting a float charger on your car in the trunk, as the battery is in there already..
  3. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,460
    768
    That's what I'm thinking too. It's only .5 amp and right now the batt. Is fully charged. Shouldn't be a problem.
  4. hellcat1
    Sep 27, 2014
    10,688
    2,038
    A lot of these cars sat for a few months outside in storage, and had no issue with the battery, mines in a heated garage, so I'm on the fence about the battery tender
  5. magnummrk
    magnummrk Platinum Member
    Sep 30, 2014
    3,828
    1,115
    918
    Wisconsin
    I will be hooking mine up under the hood. That way I can set the battery tender outside the car and see it
  6. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,460
    768
    I have a Chevy truck that sits outside and always had an issue with the battery losing charge, sometimes I won't drive it for weeks, so after I replaced the battery, I got the harbor freight float charger and use that on the truck, now I never have an issue with the battery going dead, so my logic is the same with the cat, although I will be driving the cat mostly on weekends, and using my other car for commuting during the week. Don't really know if the float is needed in this scenario, but I figure it can't hurt.
  7. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,460
    768
    The thing is that this float charger (from harbor freight) says to keep it within 3 feet of the battery. I'm not really sure this is necessary, I thought about connecting it under the hood but am not sure if it will work properly that way. It has a box with a red LED and I wonder if that needs to be within close proximity of the actual battery, in order to turn off when the battery is fully charged. Not sure.
  8. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    I have one on my SRT-8 right now in my enclosed trailer
    I have hooked them up both ways ( under the hood last season)
    direct in the trunk this season, because I am not sure what day I will have to drive it into the dealer for my trade.
    Since its locked inside my enclosed trailer, I did not shut the trunk lid all the way. Its closed but not latched.
  9. magnummrk
    Sep 30, 2014
    3,828
    1,115
    918
    Wisconsin
    This is from a Prowler site I am on. Sure looks like you get what you pay for!
    It's been getting cold here in Texas and a few weeks ago I made sure everything with a battery had a tender on it. I guess I got one of the cheap Harbor Tools Tenders mixed up with the ones for the cars. Checked the Purple car inside the small enclosed trailer and found this the other day!
    [​IMG]
    [​IMG]
  10. magnummrk
    Sep 30, 2014
    3,828
    1,115
    918
    Wisconsin
    This is what I use and have had no issues with them. $50
    [​IMG]
  11. Brampton Builder
    Brampton Builder Gold Member
    Dec 13, 2014
    434
    310
    513
  12. Dragon
    Dragon Gold Member
    Oct 16, 2014
    658
    230
    AZ
    I got mine hooked to the terminals under the hood
  13. Jim Hetrick
    Jim Hetrick Silver Member
    Dec 5, 2014
    1,338
    264
    108
    Orange County Cal
    I have eight of these, they work great, I have mine sitting in the trunk with the circle leads attached to the battery. Just plug and play.
  14. Bananahead
    Bananahead Gold Member Hellcat Car Club HCC Charter Member
    May 28, 2015
    274
    136
    Woodinville, WA
    For those of you in climates that get below freezing and stay there, putting a trickle charger like the one above also has the added advantage of keeping the battery from freezing. I have one on a generator at our cabin. Gets into the teens in the winter and stays there for weeks. Never had a problem with the battery as long as I have the trickle charger on it.
  15. Confuzed2
    Confuzed2 Silver Member
    Jan 22, 2015
    367
    92
    "GO PACK GO"
    Same brand I use, except mine is one of the bigger dual lead ones....think I paid a bit more. I live in the same area as
    magnummrk, and I've had zero issues with either car after being plugged in the entire winter. I normally just fail the trunk latch so the light goes out and keep the trunk open. But I'm sure you could carefully close the trunk too and not have any issues.
2015 dodge challenger trunk lid does not latch
battery tender 2013 challenger
battery tender for dodge hellcat
best battery tender for 2015 dodge challenger hellcat
installing a trickle charger on challenger
trickle charger for challenger hellcat
where is the batterynon 2015 challenger hellcat located
where to hook negative charger cables on hellcat battery
