For those considering 17"-18" wheels
Discussion in 'SRT Hellcat Wheels and Tires' started by Top Cat, Apr 18, 2015.
  1. Top Cat
    Nov 26, 2014
    1,925
    1,082
    768
    Doylestown,Pa
    While changing the drive shaft we had the chance to fit a 17" x 10 wheel on the charger, we decided to change the sway bar end links to a shorter set as the factory was too close when the wheel has weight on it, some thing to be aware of..
    TC
    • Useful Useful x 3
  2. B5 Blue
    1,745
    Thanks!
  3. CasualObserver
    CasualObserver Senior Hellcat Member
    Feb 7, 2015
    100
    55
    68
    No fitment issues here with a 17" x 9" Weld S77. The swaybar had a little over .5" of clearance. The car was driver to and from the dragstrip with no issue.
  4. Top Cat
    Nov 26, 2014
    1,925
    1,082
    768
    Doylestown,Pa
    It's the wider ( 10"-11") wheels that the bottom of the end link will touch
  5. CasualObserver
    Feb 7, 2015
    100
    55
    68
    Yup, and as you said, shortening up the link will tuck it into the barrel of the wheel. I'm half tempted to get an 11" wide set and go for a 325 17 Racemaster.
  6. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    697
    234
    My 18x10 wheels should be here Mon to test fit. They have a 20mm offset hoping they clear SB, If not is there a Part # of a swaybar link that is 1" shorter? Or did you use an adjustable one, they are pretty pricey. I'm hoping to find something in the Moog catalog that is OEM but shorter, or just shorten the one on there?
  7. Aaron Turner
    Aaron Turner Senior Hellcat Member
    Jan 13, 2015
    51
    40
    Elk Grove
    Just wondering if you have tested the wheels on the car yet?
  8. CasualObserver
    Feb 7, 2015
    100
    55
    68
    Me too!
  9. Top Cat
    Nov 26, 2014
    1,925
    1,082
    768
    Doylestown,Pa
  10. paul suloff
    Aug 25, 2014
    697
    234
    Just got 18x10 20mm offset Bravado wheels from Summit. Fit fine, cleared sway bar. 305 45 18 MTs on order.
    Note: when suspension is at full down (tire hanging with no load) the sway bar is very close to rim but not touching. In normal ride height there is over an inch clearance. I noticed in the first post the comment about the wheel weight would hit bar and it will with this wheel in full down but plenty of room in normal driving positions. I plan on tape weights anyway.
    • Useful Useful x 2
  11. Aaron Turner
    Jan 13, 2015
    51
    40
    Elk Grove
    Sweet, THANK YOU!!
  12. Aaron Turner
    Jan 13, 2015
    51
    40
    Elk Grove
    18x10 20 offset bravado tributes!
    They fit with no problem. 305/45/18 street 2
    • Like Like x 6
  13. CasualObserver
    Feb 7, 2015
    100
    55
    68
    Looks good!
  14. Brauner
    Brauner Active Hellcat Member
    Mar 18, 2015
    105
    30
    28
    where did you get the wheels from? I want to get a second set of wheels to mount some drag slicks on. I would prefer 18" as well for the taller sidewall
  15. paul suloff
    Aug 25, 2014
    697
    234
    Summit sells them, come in 20x11,18x10 and 20x9.5 for the front. Only problem is 18x10 black is on BO. I had to get silver and paint them. Under $200 ea.
18x10 20 offset bravado tributes black summit
18x10 wheels for dodge challenger hellcat
bravado tribute challenger
bravado tribute wheels 20x11
drag wheels for the hellcat
hellcat weld wheels
weld wheels on 2015 charger
weld wheels on charger
