Found one microscopic metal shaving ...
Discussion in 'SRT Hellcat Maintenance' started by hellcat87, Mar 10, 2015.
  1. hellcat87
    hellcat87 Hellcat Member
    Jan 17, 2015
    82
    27
    18
    Checked my cat' s oil this morning and I found one very small metal shaving but she has not consumed any oil whatsoever. I'm at 800 miles. Anyone else run into this scenario? Should I be worried?
  2. don walker
    don walker Rookie
    Nov 4, 2014
    15
    5
    initial wear... wouldn't see an issue
  3. hellcat87
    Jan 17, 2015
    82
    27
    18
    Do you think this would mean there is probably wayy more shavings sitting in the pan? Since I found it while checking the dip stick I would assume it would be worse in the internals
  4. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    I expect there would be some. Probably just luck of the draw (literally) pull the stick again and see if it happens often. I would call my service manager if it does.
  5. HellcatKid
    HellcatKid Silver Member
    Dec 21, 2014
    465
    116
    CANADA
    If your worried drop the oil and filter then cut the filter open and inspect the contents i can't imagine finding metal shavings on my dipstick but filter will tell all! :eek:
  6. don walker
    don walker Rookie
    Nov 4, 2014
    15
    5
    why mess with it.....WARRANTY!!!
  7. cereal killer
    cereal killer Gold Member
    Aug 13, 2014
    1,427
    747
    563
    Austin, Tejas
    I'd be a little concerned yes. There's a good chance that you'll see a more in your pan/oil filter. How much more is the question. I say drain and inspect.
  8. rickydl
    rickydl Silver Member
    Jan 31, 2015
    275
    96
    Ferndale, MI
    I always drain and inspect at 1000 miles.
  9. hellcat87
    Jan 17, 2015
    82
    27
    18
    Thanks guys. I'm going to drain and inspect. Hopefully it's nothing fatal for the engine :mad:
  10. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    Please let us know what you find. Now I am very curious.o_O
  11. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    70.196059, -148.559760
    I wouldn't sweat it. It's a new engine. One of the many functions of your oil is to suspend stuff like that and hopefully eventually it gets deposited in the filter.
    I would look at the oil when drained for piece of mind. Maybe also do a 1K drain as suggested.
  12. hellcat87
    Jan 17, 2015
    82
    27
    18
    Here it is
  13. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    594
    278
    Houston, TX
    I would drain and check it. I would also save some of the drained oil for analysis (mail out).
    I would do that again 2 additional times (intervals dependent on what you see from the first drain and analysis).
    Save the results and if it looks bad, go get warranty service (new motor).
  14. hellcat87
    Jan 17, 2015
    82
    27
    18
    I think I'm going to take it in to my dealer and have the mechanics start a paper trail on my engine. I hope it's nothing bad that needs engine replacement. I would be w out my baby cat for ever :oops:
  15. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,614
    508
    423
    Chattanooga, Tennessee
    That is the best idea I have heard here. Keep in mind that the dipstick measures the oil in the pan and is BEFORE being sent through the filter and into the engine. Paper trail, is good. Ask to see the filter.
