Front runners
Discussion in 'SRT Hellcat Wheels and Tires' started by Bstudey01, Apr 12, 2016.
  1. Bstudey01
    Bstudey01 Gold Member
    Mar 26, 2016
    205
    156
    413
    Racine, WI
    You guys think these will fit? They would match my rears and i was thinking of a 235 55 18 tire or so. Should drop some weight and also less rolling resistance
  2. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    681
    227
    18x8 not going to work unless it has an extremely shallow drop center, which standard productions wheels don't. The 18s for our cars are custom built and spaced out in front of brakes and are narrower. CCW and Bogart have a 5" wide. Pretty much a race only wheel.
  3. Bstudey01
    Mar 26, 2016
    205
    156
    413
    Racine, WI
    Ok thanks, maybe an 18x9 then. I think I could still do the 235s on a 9 inch rim and already have the rears. I thought it would look nice plus save on some of the rotating mass and cut times a bit.
  4. paul suloff
    Aug 25, 2014
    681
    227
    Don't think you'll find anything in 18s in conventional wheels that clear brakes. I tried most everything I could bring home from Summit. CCW, Bogart are only ones I'm aware of,Weld is working on one.
  5. Bstudey01
    Mar 26, 2016
    205
    156
    413
    Racine, WI
    Did you try the weld rts s71 in 18x9 with 28mm offset part numer 71hb8090w61a? Hhp had them on their website as fitting the front of the hellcat?
  6. paul suloff
    Aug 25, 2014
    681
    227
    rears 0nly I think. Weld said nothing they have works on front..But are working on it.
  7. Bstudey01
    Mar 26, 2016
    205
    156
    413
    Racine, WI
    Hhp says fits the front, maybe I will call tomorrow to see if they actually had them on a car .
  8. Whalecat
    Whalecat VIP Hellcat Member
    Sep 14, 2015
    110
    45
    98
    Norman, OK
    I spoke with Rich Bogart today. The front runner 18's are not yet in production, he's waiting on one more component (the center). Should be VERY soon!
  9. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,085
    523
    413
    PASADENA, CALIFORNIA
    HHP sells a skinny front wheel specifically for the Hellcats and I have seen it in person. I think it looks great. OTHERWISE you are looking at a Weld RTS 20X8 with a 5MM spacer. You have to run a 20" with the welds and you have to run an 1/8" or 5-6 MM spacer.
  10. Whalecat
    Sep 14, 2015
    110
    45
    98
    Norman, OK
    I
    I ordered mine from HHP. Not sure if you seen a prototype 18" or a 17" that's had the brakes changed?
  11. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,085
    523
    413
    They can't be 18's. There are no drag front tires made in 18".
  12. Whalecat
    Sep 14, 2015
    110
    45
    98
    Norman, OK
    M&H makes an 18x28x4.5... I have 2 brand new ones sitting in my garage that just arrived last week. They are waiting on 18x5 Bogarts to come in.
