Front Swaybar
Discussion in 'SRT Hellcat General Discussions' started by FireLane, Jan 6, 2017.
  1. FireLane
    Jul 23, 2015
    398
    117
    Palm Beach County, FL
    Has anyone tried disconnecting their front sway bar at the track? If so how much did it help your 60 foot time and was the car still stable at speeds?
  2. rayzazoo
    Nov 8, 2014
    3,967
    1,619
    818
    Knowing that this is an old drag racer trick, I'd just get stickier tires in the rear and call it a day.
  3. Silver Billet
    Silver Billet Silver Member
    Jun 5, 2016
    601
    287
    133
    N.VA
    Are you going to modify your front shocks too? You won't want to drive the car on the street with the swaybar disconnected!
  4. FireLane
    Jul 23, 2015
    398
    117
    I already have drag radials but I know that a few people with cats have disconnected the front sway bar for much better weight transfer and just wanted some input from anyone that has done it for the track.
  5. FireLane
    Jul 23, 2015
    398
    117
    I'm not going to drive it on the street like that only for at the track.
  6. paul suloff
    paul suloff Gold Member
    Aug 25, 2014
    728
    252
    My front swaybar has been off for two years. Difference in 60s is negligible. Saves some easy weight off the front. Along with an empty washer bottle; everything helps. If your not autocrossing there is no notable difference in handling. With some changes in front suspension shock valving the swaybar removal would be a bigger benefit.
  7. MAXBOOST
    MAXBOOST Silver Member
    Oct 1, 2016
    1,295
    Fuquay, nc
    I would just unhook the driver side on my old srt8. I turned the front wheel and pulled the nut off the end link just for the track. 5 min
  8. Mike Comp T/A #57
    Mike Comp T/A #57 Gold Member
    May 17, 2016
    374
    331
    513
    Batavia, Ohio
    I removed my front sway bar. I can't tell any difference in every day driving. I'm sure it helps some at the dragstrip.
    • Winner Winner x 2
  9. HC777
    HC777 Senior Hellcat Member
    Nov 25, 2016
    186
    65
    68
    I have done this to every car I have built for the last 20yrs. People that have never done this trick always freak out.That sway bar is probably 20lbs. Like mentioned above, if we had a front shock to compliment this removal, the benefits would be greater.
  10. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,417
    445
    I think the sway bar is close to 25 lbs. It's the biggest solid one ever made for a Challenger.
  11. MAXBOOST
    Oct 1, 2016
    1,295
    Fuquay, nc
    I had mine unhooked and could tell it was unhooked pretty quick. Takes 10 minutes to pull both arms at the track.
  12. Animus707
    Animus707 Senior Hellcat Member
    Oct 6, 2016
    144
    19
    48
    Would any of you guys have a video demonstration on how to disconnect the front sway bar??
  13. MAXBOOST
    Oct 1, 2016
    1,295
    Fuquay, nc
    I have run with it unhooked two times and couldn't notice any benefit in my times on the hellcat. Really easy with a electric impact and just turning the wheels to the right spots.
  14. paul suloff
    Aug 25, 2014
    728
    252
    Pretty straight forward. Will take approx 20# off front of car. Only a performance benefit if you have some hard hooking tires.
  15. HC777
    Nov 25, 2016
    186
    65
    68
    25.5# to be exact.
