Gage lights staying on
Discussion in 'SRT Hellcat Electronics' started by Brauner, Jun 11, 2015.
  1. Brauner
    Brauner Active Hellcat Member
    Mar 18, 2015
    105
    30
    28
    Had my hellcat challenger in at the local dodge dealer and after they did the latest updates my gauge lights will not turn off. The light in the gear shifter stays on as well. Anyone else had issues like this?
  2. fnkychkn
    Jan 24, 2015
    1,546
    648
    greasy cardboard box
    stays on forever or for up to a minute after key off?
    if the latter, cluster back lighting and shifter lighting will remain on until communication bus goes into sleep mode, which can take up to a minute.
  3. Brauner
    Mar 18, 2015
    105
    30
    28
    Stays on forever, it's been 2 days
  4. fnkychkn
    Jan 24, 2015
    1,546
    648
    Most likely something keeping the bus awake. Possibly the UConnect radio. Best see your dealer.
  5. B5 Blue
    1,745
    Speaking of that where are all the CAN connectors, lower A-pillars?
  6. JonWrong
    JonWrong Silver Member
    Feb 3, 2015
    358
    51
    Orlando, FL
    I had an issue like this. I had a V1 radar detector add on called Savvy, that reads speed from the OBDII port and auto mutes the detector below a set speed. It kept the ECU running and cycled the shifter and gauges on constantly. Fixed now that I removed that.
  7. fnkychkn
    Jan 24, 2015
    1,546
    648
    CAN-IHS front star connector is located behind the driver's knee blocker.
    CAN-C front star connector is located behind the glove box.
    CAN-IHS and CAN-C rear star connectors are located in right front corner of trunk (under carpet).
    challenger shown. charger similar.
    CAN-IHS front:
    [​IMG]
    CAN-C front:
    [​IMG]
    CAN-C & CAN-IHS rear:
    [​IMG]
  8. B5 Blue
    1,745
    Thanks for all you do;)
  9. Colorado Hellcat
    Colorado Hellcat Silver Member
    Nov 13, 2014
    549
    125
    Last week I ended up with a dead battery. Thought maybe it was the 25 to 35 starts I had to do moving through the staging lanes between each drag race. Next morning the battery was down to 10.5 volts.
    Used the battery charger & charged it. No more problems the rest of the week until last night after getting back from the track. Locked things up but spent some time in the garage this time & realized the gauge, center screen & shifter lights were NOT going out. Now that explains last week.
    Tried everything I could think of to. Opened & closed doors. Turned down gauge light dials & other stuff. Nothing worked.
    Finally had to disconnect the battery. Then It should down correctly.
    My money is on the Tazer that caused it. However I've been using it all summer & never had any problems until last week. Also everything was shutting down while at the track waiting in the staging lanes.
  10. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,579
    637
    My car did this for a day. Was the wierdest thing to come back to my car and hear the radio playing and see the head unit on as I walked across the parking lot. I was shopping for 30-45 minutes, radio must have been playing the entire time. It did it again at the next stop. From there started acting right...
  11. MAXBOOST
    MAXBOOST Silver Member
    Oct 1, 2016
    1,063
    359
    108
    Fuquay, nc
    Tazer will do this on very few cars.
