Gonna be looking for a magnetic oil drain plug
Discussion in 'SRT Hellcat Maintenance' started by ITSAHEMI, Nov 20, 2014.
  1. ITSAHEMI
    ITSAHEMI Silver Member
    Nov 12, 2014
    224
    87
    178
    LONG ISLAND,NY.
    I am hoping someone will come up with a magnetic oil drain plug for this oil pan. I use one now from GM for a 383 stroker motor.You will be surprised the fine particles you see on this thing when you change the oil.
  2. TallCool1
    2,401
    798
    Pacific NW
    Use a Dimple Plug -
    DRAINPLUGMAGNETS.COM
    Dimple Oil Drain Plug Specs 14x1.5x25
    Hellcat Oil Drain Plug Specs 14x1.5x20
    The extra 5mm thread length on the Dimple plug should be a non issue...
    (These are very good magnetic drain plugs speak from experience, stronger than most and correct magnet for heat range / application. But expensive...)
    It's what I purchased will be going in mine at next oil change.
    • Useful Useful x 3
  3. B5 Blue
    1,743
    Thanks!
  4. TallCool1
    2,401
    798
    Pacific NW
    Back to this, trying to find thread and detailed information for oil cooler, transmission and rear end drain plugs. To source replacements with magnets. If anyone has the specs please let me know...
  5. Trucker Bob
    Trucker Bob Silver Member
    Feb 21, 2015
    369
    91
    Northern IL
    Thanks Tallcool1
  6. TallCool1
    2,401
    798
    Pacific NW
    Oil cooler magnetic drain plugs 12x1.75x25 will be available in one month. (Also from Dimple owner getting a production run scheduled today.)
  7. TallCool1
    2,401
    798
    Pacific NW
    Here is a magnetic oil cooler plug that can work on Challenger Hellcats. NOTE- Total length of this magnetic plug is 21mm which = .83" The OE plug is 25.4mm which is 1" While this plug will work in the oil cooler, you sacrifice 4.4mm of thread length (17.6% of OE length) and if choose to use this magnetic plug, proper torque measurement would be critical; cautionary note there.
    BUY HERE IF YOU KNOW YOUR PLUGS THREAD SIZE
    Moving onto automatic transmission and rear differential plugs next...
  8. TallCool1
    2,401
    798
    Pacific NW
    This may work as a replacement for Challenger Hellcat rear differential drain plugs. Thread sizing / length is an exact match. A small raised ring around the rear diff drain plug housing may render this plug unusable, I will let you know.
    Dimple Potential Rear Differential Drain Plug - Challenger Hellcat 18x1.5x12.JPG
  9. B5 Blue
    1,743
    Any update on the diff plug TC1?
  10. SRT_HC_707
    Jan 1, 2015
    4,919
    1,420
    70.196059, -148.559760
    I didn't measure when I just did my oil change but I highly doubt there is anywhere near 25mm of thread dept in the oil pan. The oil pan isn't 1" thick and I doubt the boss is 1" thick either.
    I think the longer of the two plugs you posted is better (get the magnet further out where it can grab stuff easily), but the GM style with the seal in the head is preferable. The stock plug is like this vs. using a crush washer.'
    Thanks for the research on the plug sizes. Are you confident in the size of the oil cooler drain plug?
    I just had them both out but didn't think to check. The head (which I know means nothing) on the oil cooler drain was 15mm, the oil pan was 13mm. I was thinking the diameter was the same. Now I'm pissed at myself for not measuring diameter, length and thread pitch while I had them out!
  11. TallCool1
    2,401
    798
    Pacific NW
    I listed oil drain oe as 20mm. Haven't had chance to swap diff plug I left home when I went to change diff DOAH :mad: When I get to it I will let everyone know. Yes on oil cooler verified here by another
    Calling DrBuick SRT Hellcat Forum
  12. SRT_HC_707
    Jan 1, 2015
    4,919
    1,420
    Thanks TallCool1 DrBuick B5 Blue and anyone else that chimed in. I'll order up a valve and install next change. That's going to be a while since I just did one.
  13. B5 Blue
    1,743
    Gives you an excuse to put miles on;)
  14. Paladin06
    Sep 3, 2014
    4,642
    1,787
    San Tan Valley, AZ
    Thanks. Now for the oil cooler. :)
  15. TallCool1
    2,401
    798
    Pacific NW
    Use the oil cooler plug above I specd it's 21mm should fit.
2014 challenger eng oil drain plug sze
2014 dodge challenger drainage plug
challenger magnetic drain plug
dodge challenger hellcat magnetic oil drain plug
hellcat axle drain plug thread size
magnetic drain plug bolts for challenger hellcat
torque specs for hellcat oil cooler plug
