Harbor Tool Floor Jacks
Discussion in 'SRT Hellcat General Discussions' started by rollieman, Dec 24, 2015.
  1. rollieman
    rollieman Silver Member
    Aug 17, 2015
    274
    49
    Any suggestions on these Pittsburg floor jacks for the Challenger ?
    Plan to use with the red ZL-1 magnetic jack pads.
    So many to choose from: steel, aluminum, low profile, 2 ton and 3 ton.
    Thank you !
  2. Senderofan
    Senderofan Track in, Apex, Track out and Repeat! Hellcat Car Club Gold Supporting Member HCC Charter Member
    Aug 21, 2015
    473
    233
    Upper Midwest
    I picked up one of these a couple of years ago and have been completely satisfied:
    3 Ton Aluminum Racing Floor Jack with Rapid Pump
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Rapid Pump® high performance aluminum racing jack has a dual parallel pump system that lifts most work loads in just 3 pumps! Constructed of a high strength aluminum billet, this racing jack has a universal joint release mechanism for controlled descents of your load from any handle position. The racing jack needs just 1/2 turn release for lightning-fast pit stops!
    Pit crew quality design, machined from lightweight aircraft aluminum with
    a beautiful sapphire anodized finish
    RapidPump® exclusive dual parallel pump system lifts with far fewer pumps
    Universal joint release provides precise load control in any handle position
    Meets international quality standards
    Two piece knurled aluminum handle for a sure grip, equipped with foam
    bumper to prevent damage to vehicle finish
    Rubber saddle pad to prevent marring
    Brand Pittsburgh Automotive
    Color Blue & silver
    Material Aluminum
    Handle Length (in.) 47-1/2 in.
    Maximum Lift Height (in.) 19-1/4 in.
    Minimum height (in.) 3-3/4 in.
    Product Height 9 in.
    Product Length 27 in.
    Product Weight 55 lb.
    Product Width 14 in.
    Shipping Weight 61.31 lb.
  3. rollieman
    Aug 17, 2015
    274
    49
    Thank you Senderofan !
  4. Senderofan
    Aug 21, 2015
    473
    233
    Upper Midwest
    I have a Craftsmen steel jack....rated about the same. It's quite a bit heavier, making it harder to move around, Plus the rapid pump feature is nice and being aluminum....it won't rust. IMG_0620.JPG
