Has anybody here used or own a "Quick Jack" lift?
Discussion in 'SRT Hellcat Maintenance' started by schv, May 17, 2016.
  1. schv
    schv SRT Hellcat Supporter Gold Supporting Member
    Apr 21, 2015
    189
    131
    Pennsylvania
    My shop only has a 10 ft ceiling so a full sized lift is out, they do make a low lift twin post but you have to live with it being in the way all the time when it isn't being used. Now that I once again have a fairly low to the ground car, I've been looking at "Quick Jack" lifts (Best Portable Car Lifts for Home Garage or Shop - QuickJack USA) which get the tires 20" off the ground in fairly short order, and can be easily stored out of the way when not in use. Was just wondering if there was any reliability information/reputation on this product yet. They are a little pricey but the convenience would seem to be excellent. I'm looking at the highest capacity model....
  2. camarochevy1970
    camarochevy1970 Hellcat Member
    May 29, 2015
    78
    9
  3. TallCool1
    2,435
    825
    Pacific NW
  4. Mills
    Mills Silver Member
    Jan 28, 2015
    733
    170
    Airdrie, Alberta
    Have you looked at the MaxJacks moveable 2 post lifts?
  5. schv
    Apr 21, 2015
    189
    131
    Pennsylvania
    Looking at the options, I don't like the Quicklift because it isn't stow-able and it's a "drive on", where it doesn't get the tires off the ground - you still have to jack the car, now while it's on a lift. to remove tires. If I had a lot of room it might be useful in a secondary bay or something. The Auto lift is better but it's hard to store, and I don't want to just leave it there and drive over it because I use the floor space for other things where that would be in the way. The MaxJack is promising, and it's under consideration. The Quick Jack is still the one I'm looking most closely at (the 7000lb capacity version) because it is truly portable, requires the least space to store, is the easiest to move, and can be taken elsewhere (like the track) to use. I'm not building or restoring cars anymore so I really don't need a full on lift, and the ability to get it out of the way while not in use is primary for me (second only to safety). It's not going to see constant use and my Hellcat is the heaviest thing it will likely see unless I need to rotate the tires on my minivan or something. I guess I need to see one in use in person to feel more confident in it - the manufacturer is a subsidiary of Bendpack so they should know a thing or two about car lifts. Was really hoping a few people on here actually had them and could report their experiences.
  6. bushwhacker
    bushwhacker Hellcat Member
    Mar 22, 2015
    41
    6
    I ordered my Quick Lift on Black Friday after Thanksgiving, still haven't set it up yet, just bought it then because they gave me 10 percent off list $1,300. Bought direct from Ranger on the internet
  7. TallCool1
    2,435
    825
    Pacific NW
    No experience with Quick Jack. But I have seen them at our track, both 110ac with a small generator and the 12v dc version. Portability wise its up there, havent seen another brand at the track.
  8. Sjennings
    Sjennings Rookie
    Sep 11, 2015
    6
    0
    1
    I have the QuickJack. Have had it since February. It makes doing tires,brakes, oil changes so much easier.
    Make sure you get jacking pads or the rubber blocks that come with will mark your side skirts on the Hellcats.
  9. shadowsk
    shadowsk Silver Member
    Mar 10, 2016
    439
    South Carolina
    What jacking pads are you referring to? Link please?
  10. schv
    Apr 21, 2015
    189
    131
    Pennsylvania
    Guessing you need to use the rubber blocks included with the Quick Jack in addition to a weld seam jack point? (See the link below)
    JackPads/MagPads
  11. Max57
    Max57 Silver Member
    Apr 29, 2015
    338
    134
    Central Virginia
    The specs for the QuickJack (BL-5000SLX) states the the lift block maximum position is 60". The pinch weld lift points on our Challengers are around 66".
    How can we use the QuickJack???
  12. redhemi
    redhemi Gold Member
    Dec 9, 2014
    473
    222
    southeast Pa.
    Look at GregSmithEquipment.com they have a store in Delaware with all types of lifts !
  13. schv
    Apr 21, 2015
    189
    131
    Pennsylvania
    I was wondering the same thing, but it looks like you'd use a set of 4 pinch weld pads and lift by the pinch weld lift points front and rear. The rear pinch weld points are a little further forward than the pucks. I'm going to call Quick Jack Monday and inquire.....
    • Useful Useful x 2
  14. Max57
    Max57 Silver Member
    Apr 29, 2015
    338
    134
    Central Virginia
    Please post QuickJack's answer regarding our Challenger's lift points.
    Thanks for your time. ;)
  15. schv
    Apr 21, 2015
    189
    131
    Pennsylvania
    Will Do!
5000 or 7000 quick jack
looking for a quick jack
quick jack bl 7000
quickjack challenger
quickjack slx-5000 hellcat
quickjack used
quickjacklift
