Has anyone experienced wind sound coming from windows?
Discussion in 'SRT Hellcat General Discussions' started by Fred hellcat, May 25, 2015.
  1. Fred hellcat
    Fred hellcat Hellcat Member
    May 21, 2015
    38
    25
    18
    Im experiencing wind coming from passenger side, Sounds like window is slightly rolled down but isnt, trying to pinpoint what excatly it is and coming from. Has anyone else experienced this ?
  2. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,512
    1,425
    818
    Endless Mtns of Pa
    yes, started on my trip down south.. sounds like a air leak around the windshield or fresh air flapper valve in dash
  3. B5 Blue
    1,743
    Fold the mirror and see what happens. Can also wrap cellophane around mirror and tape it to rule out the mirror assembly.
  4. 707SRT8
    707SRT8 Gold Member
    Mar 30, 2015
    158
    65
    278
    Santa Clarita Ca.
    Have someone with you take a 3 foot piece of 5/8 heater hose and put one end to your ear and use it to pinpoint where the noise is coming from.
    • Funny Funny x 1
  5. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,101
    732
    been up to 140mph...no wind noise at all
  6. budkole
    budkole Best Color and fastest is undoubtedly WHITE
    Mar 14, 2015
    553
    188
    St. Louis
    Only been up to 129, no wind noise that I can remember. Fred, I hope its something simple.
  7. Hemikid
    Hemikid Hellcat Member
    Oct 3, 2014
    71
    14
    Saskatchewan
    I get that sound too.....sounds like mine is in the drivers side window.
  8. dr diesel
    dr diesel Rookie
    Aug 26, 2015
    4
    2
    I'm also getting wind noise...sounds like top rear corner on both sides of windows...dealer said they couldn't find anything. But it's there!
  9. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,541
    430
    368
    Henderson, NV
    I would let it go. I had an issue on my 392 where they replaced the window molding. It was never the same after that. Had it replaced twice. Apparently those moldings come folded in a box and the new ones never straightened out. They wound up pulling one off of a new car.
  10. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    1,981
    472
    403
    Westchester
    all challengers had this issue since 08, It's a seal issue. Ca
  11. Fionn MacCumhaill
    Fionn MacCumhaill Irish A'Hole - Wanna Fight About It!? Hellcat Car Club HCC Charter Member
    Nov 14, 2014
    605
    298
    Denver Colorado
    Also make sure your window is auto rolling up after you close the door; ya know that 1/4 inch it moves when you open it or close it. I have noticed sometimes my window doesn't go back up after i get in the car and close the door, I just hit the switch and it goes up the 1/4 inch it goes down when I open the door, but I have not noticed it and stated driving and heard a wind noise before, that's when I realized the window was down a bit. Also noticed it a few times when I have gotten out and went to walk away and see the window is still down a little; problem with that is I then have to get back in and key cycle it before it rolls up when i get out.
  12. Kansas City Chris
    Kansas City Chris Rookie
    Oct 19, 2015
    17
    11
    Just got my cat back from the dealer and I complained about the same wind noise coming from the passenger side. My drive side glass doesn't make the same noise because the door is gapped tighter to the back of the car so the glass is covering more over the weather strip.
    He said: "Inspected weather strips at door glass and all look good. Road tested with service director and heard a small amount of turbulence not wind noise. Glass specialist came out and inspected and advised the glass is sealed and cutting it would do nothing to change this. Advised we use dry lubricant on weather strips and if noise persists will have to schedule with body shop to try and close small gaps."
    He gave me a can of this CREST Dry Lubricant ill spray on a paper towel and rub on my rubber..... we'll see if the rubber holds. haha If it doesn't help ill schedule my car to go into the body shop and get the door re-aligned. Miss the days you could just move in the striker and get the door to seal a little better, but on these new cars the striker is set and the only way to align the door is by the hinges.
  13. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    5,254
    2,187
    568
    The right way to fix it is to have a tech drive the car and tape different areas to pin point the noise. Should be a easy fix but time consuming for the tech who fixes it. Warranty won't cover 3-4 hours that it could take or even more. Dealership would have to take care of it. I hope it's fixed for you and good luck with your car
  14. Kansas City Chris
    Oct 19, 2015
    17
    11
    The dealer pin pointed the area and said its due to alignment. The door needs to come back ever so slightly so the glass is better seated on the weather stripping. If my fiancée keeps complaining about it in a few weeks like take it back to them since they told me warranty will cover it. I'll let you know if the dry lube doesn't work and I take it and if they fix it.
  15. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    5,254
    2,187
    568
    Just stick to your guns and insist it gets fixed. The right way to do it is as I mentioned. I am not aware of tsbs or any bulletins. If you wish pm your vin and I will check for you. Last 8 of vin
sondmaker after wind at window
weird noise driver side challenger hellcat
wind noise driver side challenger hellcat
