Has anyone had a check engine code P1611 ?
Discussion in 'SRT Hellcat General Discussions' started by ramair111, May 4, 2015.
  1. ramair111
    ramair111 Silver Member
    Mar 10, 2015
    144
    43
    178
    My check engine light lit up first morning when I started car. Drove 25 miles to dealer and they took it right in and checked it over for two hours. Looked for any reports of this and found none. They reset and its been fine for 200 miles. Code was a super charger sensor reading high.
  2. B5 Blue
    1,743
  3. ramair111
    Mar 10, 2015
    144
    43
    178
    B5, it was built around March 25th, they did not find any TSB"s on it.
  4. B5 Blue
    1,743
    That takes it out of the range. We need fnkychkn to give us his insight and the DTC parameter
  5. fnkychkn
    Jan 24, 2015
    1,447
    555
    423
    plastic take-out container
    can't say I've ever seen this code.
    P1611-SUPERCHARGER BYPASS VALVE POSITION SENSOR 1 CIRCUIT HIGH
    Theory of Operation
    The Supercharger boost pressure is managed by the use of a Supercharger Bypass (SCB) Valve. The PCM can vary the position of the SCB Valve to control the amount of boost. The SCB system uses two Position Sensors to monitor the SCB blade position. Position Sensors are located within the SCB Valve assembly. Each sensor has its own Signal circuit. Both sensors share a 5-Volt reference circuit (Supply) and a low reference circuit (Sensor Return). The Powertrain Control Module (PCM) monitors the SCB Valve Sensor data. Each Signal circuit provides the PCM with a signal voltage proportional to SCB blade movement. The PCM monitors the data to verify that the indicated SCB position is correct.
    When Monitored: This diagnostic runs continuously when the following conditions are met:
    • With the ignition on.
    • Battery voltage greater than 10.4 volts.
    Set Conditions:
    • The TPS 1 Signal voltage is above the maximum calibrated threshold.
    Default Actions:
    • The MIL light will illuminate.
    Possible Causes
    5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
    SCB VALVE SIGNAL 1 CIRCUIT SHORTED TO VOLTAGE
    SCB VALVE 1 SIGNAL CIRCUIT SHORTED TO THE 5-VOLT SUPPLY CIRCUIT
    SCB VALVE SIGNAL 1 CIRCUIT SHORTED TO THE SCB VALVE CONTROL (+) CIRCUIT
    SCB VALVE SENSOR GROUND CIRCUIT OPEN/HIGH RESISTANCE
    POWERTRAIN CONTROL MODULE (PCM)
    • Useful Useful x 5
  6. F6F
    F6F BANNED
    Dec 19, 2014
    2,089
    1,014
    668
    Team Hellcat, MD
  7. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,668
    2,027
    So where are these scb at l on the engine/ supercharger. . Can you upload some pictures
  8. B5 Blue
    1,743
    If it's using 2 position sensors one should increase while the other decreases. If it's not hardwired from PCM to sensor I would suspect the connection in between and in either case check the pin fit but I have no wiring diagram. I seriously doubt it's the PCM.
  9. hellcat1
    Sep 27, 2014
    10,668
    2,027
    This gets the wheels in my head turning.....thinking only good things
    • Funny Funny x 1
  10. fnkychkn
    Jan 24, 2015
    1,447
    555
    423
    [​IMG]
    • Useful Useful x 3
  11. Zebug
    Zebug Gold Member
    Nov 11, 2014
    2,603
    863
    628
    Houston Texas
    Fnky is right there with RS for this community. Thank you for your contributions
    • Agree Agree x 4
  12. hellcat1
    Sep 27, 2014
    10,668
    2,027
    Hmmmmmm, maybe there is a way to tweak this to stay open longer/ or closed longer????
  13. B5 Blue
    1,743
    I second that!
  14. B5 Blue
    1,743
    Doc was playing with the valve, it's an 80mm throttle body if my memory serves me right
  15. ramair111
    Mar 10, 2015
    144
    43
    178
    The tech checked all of the circuits and connections and found nothing wrong. Excellent service no waiting, took it right in and got to work.
challenger hellcat p1611
dtc p1611
engine codes 2015 dodge charger hellcat
hellcat p1611
hellcat p1611 code
how to read codes in dodge hellcat
p1611
p1611 code review
