Having a problem with Barton shifter
Discussion in 'SRT Hellcat Performance' started by EVIL CAT, Jun 12, 2015.
  1. EVIL CAT
    EVIL CAT Senior Hellcat Member
    Jan 26, 2015
    28
    NW Suburbs Chicago
    Hey guys, so my guy just installed my barton shifter and I found that moving over to reverse is REALLY hard. I mean really hard. Does it have to be adjusted over to the left a little? Any help is appreciated, thanks guys.
  2. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,837
    1,336
    933
    Kenosha, Wisconsin
    Where did you index the handle at? Towards you or the opposite? Also, are you sure you have the rear most mount positioned the right way? Im talking about the one that holds the rear of the assembly up and attaches with a nut at the top. That CAN be installed 180* off and cause binding.
  3. EVIL CAT
    Jan 26, 2015
    28
    NW Suburbs Chicago
    I wasn't there for the install I was at work myself, but from what it seems the handle is more towards me but maybe it needs to be more? I know what assembly you're talking about as well cause I messed with it a little bit before it was in. I'm assuming it shouldn't be as hard as I say it is to throw in reverse
  4. cruizinrc
    cruizinrc HCC New Jersey State President Hellcat Car Club HCC Charter Member
    Jan 26, 2015
    880
    405
    Installed mine myself at midnight last night and mine goes in reverse no problem have him check his work also maybe just remove shifter boot to see if it's hitting anything
    Ron
  5. iya0yas
    iya0yas Silver Member
    Nov 10, 2014
    634
    155
    Gastonia, North Carolina
    I'm considering the Barton shifter as well. What are the advantages v. the stock shifter? I haven't owned a manual trans in a long long time so i have no point of reference to compare with my M6. It feels fine to me as I'm getting used to the gates & throw. Thanks for your thoughts & impressions.
  6. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    It should not be hard to shift in any gear. get it set up right before you drive it
  7. cruizinrc
    Jan 26, 2015
    880
    405
    Biggest thing I noticed was no slop and very precise
  8. EVIL CAT
    Jan 26, 2015
    28
    NW Suburbs Chicago
    I had figured it shouldn't be difficult at all to go into reverse. I would take the shifter boot apart but I'm out of town at the most inconvenient time. The car is with me but I have no tools here. Especially no plastic trim tool. Thanks a lot guys I just wanted to clarify. But as to the quality and feel of the barton shifter it's incredible, I highly suggest it to anyone with 6M
  9. Aaron Vogel
    Aaron Vogel Gold Member
    Jan 23, 2015
    1,847
    331
    Everywhere
    As another has posted it is a much firmer solid shifting unit. It also has a nice little "spring" to it when you are going 2-3 it wants to already straighten out as you move from 2 to 3. Which is really good when you are in it, or racing and your doing No-lift-shifting (one of the perks to our 6spd vs other ones), you can just hammer from 2-3 and it will fall right into place then striaght back to 4th. Its a nice setup for sure
  10. 70Cuda
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    the hellcat shifter is better than my 2012 SRT shifter but not that much. I am thinking a Barton will be the way to go.
  11. Aaron Vogel
    Jan 23, 2015
    1,847
    331
    Everywhere
    The Hurst is a good unit to, i have one with the upgraded 440 Rod, also a nice, tight shift. Not as much of a work out as the Barton can be, but also a firm unit
  12. 70Cuda
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    sounds like I get to do some research.
  13. iya0yas
    Nov 10, 2014
    634
    155
    Spoke with a tech from Hurst and he said they do not have a shift kit for our HC's... So based on others posts they actually do have a kit available???
  14. Aaron Vogel
    Jan 23, 2015
    1,847
    331
    Everywhere
    They have it listed for the Scat Pack, i don't see why it wouldn't work in a Hellcat, its the same shifter i believe. But sorry, i was speaking from using both units in my 2010 Challenger. But i would be curious to see what the tech says if you asked him about if there is a difference between the Scat and Hellcat shifter
  15. Harley88
    Harley88 Gold Member
    Nov 15, 2014
    1,350
    434
    368
    I've got the Barton on my '14, I like it.
    But I won't be changing the Cat. Not enough bang/buck. My 2cents.
    The "viper" manual is sweet!
2009-2015 challenger barton shifters kits for sale
barton shifter 2015 challenger
barton shifter challenger
barton shifter challenger for sale
barton shifter problems
barton shifter scat pack
problem hellcat reverse gear
